how to upgrade to posi rear?
Old Jul 31, 2000 | 09:36 PM
opieum's Avatar
Hey guys.. i just picked up my 92RS, and i ahve no traction on that rear right tire.. i floor it and feel the car jerk.. even at 70 mph.. from a dead stop and can cruise calmly up 15mph and floor it, and loose traction.. i want to upgrade to posi.. i herd it was as eas as replaceing the diferential[sp] .. how much is the unit? whats teh bes tone to pick up? and how mcuh does it cost to be installed? thanks
-opieum
"the meaningless post master"
92 Stock RS
Team Portal Security founder
FL Thirdgeners BB
#6 on the SETI project. click here to view our(thirdgen.org) stats
and im terrin it up with my Athlon 650 and 384megs of ram.
aim: opielight
opielight@hotmail.com
Old Jul 31, 2000 | 09:52 PM
Polecat's Avatar
You can get one from SLP or get a locker from Summit called the Powertrax locker. With basic tools you can install it yourself in a couple hours in the driveway. that will give you the lockup on both tires you need.
Both lockers are very good.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Aug 1, 2000 | 12:30 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Since you have a 92 with 28 spline axles, you just need the take-off posi unit from SLP. You will also need 3.23, 3.42 or 3.73 gears, and you will have to change the speedo gears in the trans to fix your speedometer. Do you have an automatic or a stick? 3.23 or 3.42's are nice.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
Old Aug 1, 2000 | 02:56 AM
SillyWabbit's Avatar
Car: '91 Formula
Now if I already have 3.42's and just want a posi rear, would it be necessary to screw with the speedo gears in the tranny?
Old Aug 1, 2000 | 08:18 AM
Carbonsteel's Avatar
Try and pick up a fourth gen rear from a wrecking yard. The site even has a tech article about it if your interested.
Old Aug 1, 2000 | 01:45 PM
opieum's Avatar
its an Auto..... and what gears do i ahve now?
-opieum
92 Stock RS
FL Thirdgeners BB
aim: opielight
Old Aug 1, 2000 | 02:51 PM
Kevin91Z's Avatar
No, its not necessary to fix your speedo gears, but it will read wrong until you.
If you have 3.42 gears and are putting in a posi with 3.42 gears, then you're ok.
All TBI RS's have 2.73 open rear for automatic, and 3.08 open rear for sticks.
Old Aug 1, 2000 | 03:29 PM
opieum's Avatar
So, To answer my question. I need to reaplce the Diferntial[sp] and my rear end gears, and the tranny gears, so the speedo reads correctly? and the 3.42 gears are recommended?
-opieum
92 Stock RS
FL Thirdgeners BB
aim: opielight
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
