computer problem HELP!!!!!!!!!!!!!
Old Jul 28, 2000 | 11:40 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
ok here's the deal. I brought my car to the mechanic's today cause he detected a misfire....he scanned the computer for codes and something came up i don't remember the code but the MAF isn't getting enough voltage. My TPS readings were in the 60's! i don't know what it means but i know its bad! I've had this fastchip for a while now but my mechanic thinks thats the cause or my ECM is fried....he thinks maybe the chip cuts the voltage to make it run rich(which the computer said) so what do u guys think??????? HELP!
89 GTA 350 TPI(L-98)Fiberglass "Daytona Turbo" hood the all mighty K&N filter air foil Stage 2 Fastchip(great chip!) B&M Stage 2 shift kit Flowtech(hey they work fine) shorty headers SLP 3'' stainless steel cat-back exaust Crane Cams HI-6S igntion with PS-91 coil MacEwen white gauge overlay's SLP rear sway bar Koni's all around and one kick *** stereo! Ported plenum and SLP runners are waiting to be installed.
You can see a pic of it by going here:
http://www.hometown.aol.com/clarkemustgonow
Old Jul 29, 2000 | 08:28 AM
fly89gta's Avatar
Car: 2018 Camaro SS
anyone??
Old Jul 29, 2000 | 10:06 AM
Vader's Avatar
fly,
If you're getting a MAF error code, you should start looking there first. I'm thinking that the mechanic already knows this, and since you've enlisted his help, you probably don't want to undermine his plan of attack. If you've decided to repair it yourself, that's a different situation.
If you are going to repair it yourself, you'll need to scan for error codes. I understand that this has already been done, but you'll need to learn to do it anyway since you'll have to do it later to confirm the repair.
Follow the instructions listed in the Tech Articles on this site.
Later,
Vader
"Some Body...Someone"
Old Jul 29, 2000 | 08:40 PM
fly89gta's Avatar
Car: 2018 Camaro SS
vader.....he's taking care of it...i don't remember the code but it said the MAF isn't getting proper voltage..it didn't say the MAF is bad...just little voltage...i'll try to find out if there is a specific code for that on monday..i'm not touching it....i e-mail ed wright to see if the chip cuts the voltage to the MAF but i doubt thats the case...would it be a bad ECM then?
Old Jul 30, 2000 | 06:27 PM
fly89gta's Avatar
Car: 2018 Camaro SS
anyone else have anything to add?
Old Jul 30, 2000 | 07:27 PM
SSS's Avatar
SSS
I was getting that code on my 86TA. I replaced the MAF power relay and the problem went away.
Old Jul 30, 2000 | 07:41 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
There are many components in the mass air flow system. If the mass air flow sensor is not receiving the correct voltage, it could be corroded wiring, bad relays, poor connections, bad grounds. I would check all of theses items before I replaced the ECM. When I bought my car it had a bad MAS relay. The relay was corroded and it did not allow enough power through to operate the MAS. I found the bad relay by doing voltage drop tests on all of the connections. Once I replaced the relay everything worked correctly.
Old Jul 30, 2000 | 10:43 PM
fly89gta's Avatar
Car: 2018 Camaro SS
how much do MAF power relay's generally run?
Old Sep 10, 2000 | 11:43 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
The power and burnoff relays are around 10 to 11 dollars each at the dealer. First step I would take is getting that TPS voltage down to around where it's supposed to be, .54vdc. .60 is ok, it's within tolerance, just that you want to set everything as close to spec as possible when you are troublshooting the MAF system.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
z28addict8490
Sep 5, 2015 03:56 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
perZ
Aug 15, 2015 01:17 PM
