What AFPR do u guys think is the best??
Old Sep 10, 2000 | 11:22 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Old Sep 10, 2000 | 11:25 PM
Vader's Avatar
AFPR.pdf.
Later,
Vader
"Some Body...Someone"
Old Sep 10, 2000 | 11:26 PM
Kevin G's Avatar
I bought the Accell one for 65 bucks through Summit, and it uses the existing AFPR..But Vaders link is very cool. I would go that route.
[This message has been edited by Kevin G (edited September 10, 2000).]
Old Sep 11, 2000 | 12:19 AM
Dan87IROC-Z's Avatar
I hear the Crane one is the only one to stay away from, because the adjustment screw hits the plenum.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Components, K&N Filters, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.3 @ 97mph
Old Sep 11, 2000 | 12:42 AM
Vader's Avatar
...and mine comes pretty close.
Later,
Vader
Old Sep 11, 2000 | 12:44 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Vader, I can't get any of your downloads to work. Any suggestions??
evilho7810's Avatar
I think that the tpis is the best.
Old Sep 11, 2000 | 12:45 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Double Post!!
[This message has been edited by IROC-ZTWENTYGR8 (edited September 10, 2000).]
Old Sep 11, 2000 | 08:53 AM
Cntrvrsy's Avatar
Accel or maybe even Holleys new 1. I've tried Hypertechs and Cranes which is all the same thing and they suck big time! Crane's hits the plenum and the other 1s adjustment screw had bent under the cover. Accels is real sturdy and uses an allen key 2 adjust.
Old Sep 11, 2000 | 09:02 AM
Bill91Z
Guest
Posts: n/a
Have TPIS and have no complaints whatsoever.
-Bill
1991 Z28, 305TPI, 5-speed,
AS&M ported & polished intake, AS&M polished LTRs, AS&M port matched plenum, TPIS 52mm TB, Richmond 3.73s, SSM SFCs, SLP LCAs, SLP panhard, ATR 3" exhaust, MSD 6al, Taylor 10mm wires, SLP PROM, and a host of other stuff.
Old Sep 11, 2000 | 10:29 AM
Yarnboy's Avatar
I sure hope this is a worthy mod..it looks like a pain in the *** to install dealing with all the o-ring replacing and such..Is it really as annoyong as Haynes makes it look?
Red '88 IROC 5 Speed TPI
Dual Friction Stage III Centerforce Clutch
Accel 300+ Racing Ignition
Accel 300+ Pro Sleeve Plug Wires
Accel U-Grove Plugs
Flowmaster Force II 3 Chamber Cat Back Exhaust
Hypertech Chip
Old Sep 11, 2000 | 10:47 AM
Cowboy's Avatar
I've got the Crane unit and the bolt did hit the plenum. Went to Lowes and for 6 cents I had a bolt that worked. Even with the added money from the extra bolt, I believe the Crane is still the cheapest other than homemade.
Old Sep 11, 2000 | 10:57 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got the accel one and no matter what I do with the screw, my fuel pressure stays between 45-47psi. The screw will also come into contact with the plenum if you unscrew it a bit. I've got a new FPR to install to see if I can get more or less than 45-47psi because I'm not sure why it won't deviate.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 11, 2000 | 11:08 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
I have the holley one waiting to be put in. I only paid like $60 for it on carpartsonsale.com. It is going to be real easy to adjust it to because the whole top spins.
Old Sep 11, 2000 | 11:44 AM
Bill91Z
Guest
Posts: n/a
Yarnboy...this is not a difficult mod at all. All you have to do is remove the TB and plenum. All you are really replacing is the "hat" to the FPR. It should come with a new gasket and that's really it. The internalls to the FPR are re-used and put into the new hat. The Haynes manual always makes it seem more difficult than it is.
It's easy, trust me.
-Bill
Old Sep 11, 2000 | 12:18 PM
rondubbs's Avatar
i have a tpis one and think it is garbage,, the vacuum piece breaks off very easily.
Old Sep 11, 2000 | 12:29 PM
Bill91Z
Guest
Posts: n/a
Ron, this is the problem I have been frequently hearing about the TPIS AFPR. I have yet to have problems, but I have heard of a lot of people having the same problem as you. So people, you have been warned!! lol
-Bill
91Z28, (in progress) 3.8L, TE63-1 turbo, MSD50lb injectors, Hemco upper,ported TTA heads, 62MM TB, Red's XP fuel
pump, 3.73s, vigilante (stall to be determined)
Old Sep 11, 2000 | 08:58 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Of course you could always make your own and save yourself some money. Should cost you around $0.40 to make.
Old Sep 11, 2000 | 09:54 PM
Vader's Avatar
IROC,
You need to have Adobe Acrobat REader installed to open the files.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
