Take a look at my "new" messed up block
Old Sep 12, 2000 | 02:21 PM
Blade's Avatar
Well here my oil burning problem. I thought it was as simple as changing rings when I pulled it out. To my surprise... I see big hole in the cylinder wall, carved by the wrist pin. It looks like it slid out and scractched the hell out of my cylinder wall. The wall is so thin now, the block is trashed. Anyway... here's some pics
And two more here... http://www.truspeed.dhs.org/wall1.jpg
http://www.truspeed.dhs.org/wall2.jpg
Any comments on using a 92 truck block with supposedly vortec heads on it ? I'm not gonna be using the heads.. just the block. It's only 100 bucks so I cant pass it up. hehe
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires...
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Old Sep 12, 2000 | 02:55 PM
NO RICE's Avatar
If those are vortec heads and you're getting them for cheap, I'll buy them..
Post the head casting numbers and how much you want for 'em?
Thanks...
Old Sep 12, 2000 | 03:59 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
I'll personally vouch for a truck motor working in a Camaro. I blew up my L98 and found a 350 from a truck for only $50. Just swap over all the sensors and everything. I dropped it in, everything matched up and it runs great!! If you have any questions let me know but the blocks are just about identical as far as I could tell.
Go Hokies!!!
Old Sep 12, 2000 | 04:24 PM
ede's Avatar
ede
if thats your only problem (like it's no big deal) you can save the block with a sleeve for less than a 100 dollars.
Old Sep 12, 2000 | 04:36 PM
Kevin G's Avatar
Damn, I havent seen that before!! That is pretty wild looking.
Vortech heads on a 92?? Did someone put them on there?? I thought Vortech heads came later, in 95 up trucks
Truck blocks are great, and it should be a 4 bolt block(most came with them)
94 Z28-M6 S-Trim
-=ICON Motorsports=-
Old Sep 12, 2000 | 05:15 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
C'mon over to my place, I have a sister to your block....although I have 6 cylinders that look like that
I think the idiot who pressed the pins in thought he'd make an easier job for himself and open up the holes in the pistons...least that's what I'm figuring happened on mine..only had 3K on the block...
Old Sep 12, 2000 | 06:31 PM
ZBRA's Avatar
Car: 1972 Corvette
Where are you at? I am trying to sell my original L98 out of my '91 for $250, but I don't want to ship it. It has no damage and has never been bored. It is disassembled though. I pulled it in favor of a ZZ4. It is the motor only. No intake, sensors, accessories, distributor, etc. Let me know if you are interested. I am in Baton Rouge, LA.
'91 Z28 Blue/Silver ZZ4/ZF6
335.9 rwhp 374.9 rwtorque
Old Sep 12, 2000 | 08:13 PM
Hurtin4Hp's Avatar
Car: Transformed 86 Coupe
Engine: 400 sbc
Thats a first for me too! Who assembled the engine? Are the wrist pins press in or bushed?
Old Sep 13, 2000 | 01:00 AM
Blade's Avatar
The engine was assebled by Spartan (bough it from Checker auto parts). I believe they were pressed in. Now they wont warranty it because it has a different cam in it...
92 Z28 L98 350
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
86z89iroc
Oct 5, 2015 01:04 PM
Jonas Earl
Sep 27, 2015 07:39 AM
GTAman
Sep 26, 2015 02:01 PM
RyanJB
Sep 14, 2015 03:39 PM
