500 HP Possible with ported Vortec heads?
Old May 27, 2003 | 08:16 PM
ChevTech84's Avatar
I know alot of you are making 400 or more with Vortec heads and a variety of cams. My Vortec's are being ported (chambers, guides, and runners redone). Is the GM Hot Cam Kit with 9.75-1
compression and a Holley Street Avenger 770 carb going to put me anywhere close? Any suggestions would be greatly appreciated.
Old May 27, 2003 | 08:51 PM
89irocbeast's Avatar
Well first off how much hp do you have now? all the porting and what not should help, i know that the cam makes a good power increase on lower hp engines but im not sure how much good it will do if your already in the 400s. Maybe get a custom grind cam, the carb should be pretty good but im not really up on the carbed motors so dont take my word for it. good luck
86budgetSC's Avatar
I severely doubt your going to get 500 horse with that combo
You didn't list the specs on the cam.The largest cam that GM has in the hotcam kit is .493/.512 lift with 257/269 duration.I don't think that is enough compression to make good power with even that cam.
Just my thoughts.
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
sounds pretty good to me.
Stock Bore? I am going to say that it all depends on how well these heads of yours are ported. Car Craft just got about 470 horse out of a Vortec setup ( ported heads) with a Comp Xe 268 or 274 ( can't remember but I'm pretty sure it was a 268) . You are going to have more compression ( about 1 point) as well as a larger cam, so I am going to say that if you heads are ported properly you'll be close to 500 horsepower, probably right around 485-490.
Make sure you use and Air Gap intake and not a performer rpm or Victor, the Victor will cost you a bunch of torque and the performer rpm will cost a bit of both hp and lb ft.
Old May 27, 2003 | 09:03 PM
ChevTech84's Avatar
I don't know how much the motor is making currently, it's a
work in progress. The bottom end was just balanced and the porting work is currently under way. I forgot to include the fact I'm using Manley Race Flo valves and an Edelbrock Air Gap RPM manifold gasket matched with the heads. I'm also using a Diamond Stripper windage tray if that makes a difference. My firend built a 383 w/ Vortec heads that made 500 HP to the rear
wheels, but I am not sure my 350 will make that much at the fly-
wheel.
Old May 27, 2003 | 09:22 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
330hp, was that on a 350 or a 383? I didn't know they made that much on a 350. I followed upto 440hp 350, but I didn't know they got more.
Old May 27, 2003 | 09:26 PM
ChevTech84's Avatar
The cam lift on the Hot Cam kit I bought is .525/.525. I bought the single pattern cam because I figured after the porting was done to the heads a dual pattern would over scavenge the exhaust. Being the biggest increase is exhaust flow on most heads. I also bought the MSD coil in cap, module and wires for
firepower.
Old May 27, 2003 | 09:29 PM
johnsjj2's Avatar
Car: 1991 Z-28
330hp, nevermind. I just went to Car Crafts website and found the article. Almost makes me want to pull my heads after a whole 60 miles on the engine and run through them again!! Almost, but I think I will wait.
Old May 28, 2003 | 05:44 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Yeah no kiddin'
It's a pretty encouraging article isn't it. I can't wait to be pulling over 450 horsepower out of a 355. Then I'm either getting a Vortech or ATI Blower for it. We'll see if I can get it over 650 horse, shooting for 700. Not to mention, aside from the paint, it'll be a sleeper with no crap sticking up out of the hood.
What kind of 700 r4 can handle the abuse of 700 or so horsepower and how much do they cost?
I already know I'm going to blow my rearend apart but I'm gonna wait until I do to change it out.
Old May 28, 2003 | 05:56 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
stock the vortecs will support 450...so ported i dont see why they wouldnt support 500 horse...but its all in the combo
my combo is
LT1 shortblock
ported LT4 heads with 2.02/1.60 valves
comps 502 LT1 grind on a 110
GMPP LT4 dual plane intake
im expecting no less then 450
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
