LO3 Potential?
Old May 28, 2003 | 06:34 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
LO3 Potential?
without any sarcasm or "get a 350" comments...
what could one expect from a LO3 if you put a fairly mean street roller cam (better than LT1 cam) and an intake, and long tubes.
a fairly mean little beast right? what if you add port and polish to them heads....or are they not worth it....what would be a good HP replacement for CHEAP?
im hoping to rely on my 305, 6 speed and a serious suspension to keep me happy at the drag strip til i can build the 420....the right way.
thanks
Rick
Old May 28, 2003 | 07:45 PM
Dan88IrocZ's Avatar
From what I've seen...swap heads and expect low 13's.
Edit: Thats with a TBI to carb swap.
Old May 28, 2003 | 10:46 PM
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
for heads that give you the most bang for the buck I would go with some high-lift vortec heads, they are under 700 bucks for the pair and can take something like .550" lift. Not to mention that being a genuine gm product you wont have to worry about reliability....oh yeah, you'd have to get an intake to match the bolt pattern too.
Old May 28, 2003 | 11:13 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
As the others are trying to say, you won't get anywhere with those LO3 swirl port heads. Get rid of them before you try any other improvements.
Ditto on the exhaust. Long tubes aren't necessary, but getting rid of all the factory exhaust is.
"GM reliability"? Vortecs are "production quality castings", but I wouldn't use that in the same sentence with "reliable". Any aftermarket casting would be better in that regard.
Old May 28, 2003 | 11:30 PM
pwood02's Avatar
Car: '86 Trans Am
Engine: 355
I was just refering to the fact that machine shops say that the factory valve job on those heads are excellent, and a good three- angle job propably wouldn't be any better. I know what your saying and I agree, I was just trying to state that you aren't buying a junk head from some off-brand manufacturer.
Old May 29, 2003 | 07:25 PM
Car: 90 Camaro RS
Engine: 305 TBI
thanks guys...your answers were what i expected....ditch the heads...and maybe i can get 13s.
thanks
Rick
Old May 29, 2003 | 09:05 PM
Vader's Avatar
You may have the power to break into the 13s, but you'll need to address the traction issues of the chassis before you get there.
Old May 29, 2003 | 09:13 PM
Car: 90 Camaro RS
Engine: 305 TBI
traction issues of the chassis?
do you mean i need to modify the suspension?
if you do then...(in my first post i said 'serious suspension' would be part of the package)
but if you mean something else...what?
a roll cage ?
Old May 29, 2003 | 10:18 PM
Dan88IrocZ's Avatar
SFC's.
Then buy some big sticky meats & LCA's.
Old May 30, 2003 | 12:43 AM
Car: 90 Camaro RS
Engine: 305 TBI
ya i was gonna do the full line of spohn products as i have his torque arm and crossmember. i was thinking qa1 shocks in the rear and lakewood 90/10s.
either eibach drag springs, or iroc springs.
and i was gonna pick up some rally rims or something and get some slicks for the weekend.
we'll see.
4 10s
6 speed
aharvel50
Sep 21, 2015 07:31 PM
anesthes
Sep 21, 2015 10:24 AM
64Chief
Sep 12, 2015 08:05 AM
Stroopwafel
Sep 11, 2015 06:38 AM
