fuel filter change
Old May 31, 2003 | 01:00 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
fuel filter change
88 TBI V8--can some one breifly out line the steps for me?
thanks!
Old May 31, 2003 | 01:11 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Ok first crawl under your drivers dash and look for the fuel pump fuse. It is labled. Pull it out. Then run the car till it runs out of gas.
Jack up the drivers side rear and put it on jack stands.
Fine the filter on the frame rail near the tank.
Remove and reinstall.
Easy process.
Old May 31, 2003 | 08:13 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes. unless it hasn't been change for years and is rusted to hell and back. Then this easy process turns into work.
Old May 31, 2003 | 10:32 AM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
put a can or bin underneath it because it will drip some gas, i put a rag over it while i unscrewed it and let the can catch the gas. other then that its just unscrewing 2 nuts and install is the reverse. make sure u put it on in the right direction and to check for leaks after.
Old May 31, 2003 | 11:59 AM
MdFormula350's Avatar
mine wasnt changed for awhile and maybe was even the stock one took some force to break the nuts loose, some pb blaster helped in that respect.
Old May 31, 2003 | 04:48 PM
avro206's Avatar
Car: 89 Formula
thanks---got it done--was about 3 yearrs ago I had it changed--came off pretty easily.
Pulled 3 fuses beofre I picked the right one--although one I pulled the engine idled real low--the inj fuse killed it.
Word for the wise.....gasoline in your armpit hurts!
Old Jun 1, 2003 | 01:24 AM
Transmission: 4l60e
when I changed mine I had no way to relieve the pressure because the pump was dead.
I took those lines off and there came the gas...and it wouldnt stop.
I had gas all over me. Gasoline on your scalp hurts so bad. So much gas went onto the blacktop that it ate it away. I sprayed a punch of concrete away with the water hose.
Old Jun 1, 2003 | 01:30 AM
IrocAngel305's Avatar
ive had gas spray onto my face, hair, ear and eyes before its not fun. Today when i changed my fuel pump and was disconnecting the lines i got the pleasure of gas spraying out of control and soaking me lol
Old Jun 1, 2003 | 12:14 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
it works really well 2 wake ya up in the morning tho! about a week ago i went into work a tad hung over and the first job they gave me in the morning was a fuel pump in a jeep grand cherokee, a job i've done many times before.. i pulled it in drank a cup of coffee, then proceeded to put it up in the air and unhooked the fuel line covering myself from head to toe with gas... everyone had a pretty good laugh except me. lol
Old Jun 2, 2003 | 12:58 PM
TransAmTBI's Avatar
Engine: 305 TBI
Transmission: th700R4
anyone have the part numbers or refrence for autozone? price?
Old Jun 2, 2003 | 02:20 PM
TekViper's Avatar
Engine: 3.1L v6
just tell them u need a fuel filter for whatever car you have. its very common part, pepboys has an isle with nothing but fuel filters. i think mine was about 8 or 9 bucks.
Old Jun 2, 2003 | 10:04 PM
TransAmTBI's Avatar
Engine: 305 TBI
that was the worst experience of my life... i was practicallly bathing in gass! it really sucked... the car would not stop running after I started her up with the fuse out! anyway i lost about 3 gallons of fuel and here in jersey at 1.60 ish a gallon for super! that sucks lol
at least i have a new filter now.
Old Jun 2, 2003 | 10:30 PM
avro206's Avatar
Car: 89 Formula
hmm...I pulled the fuse out WITH it running---dies 2 seconds later. That was after I got the right fuse....f/p wasn't it...inj was.
I feel for ya though
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
maroe624
Apr 16, 2017 08:29 AM
Logan Bryant
Aug 27, 2015 11:52 AM
92camaroJoe
Aug 13, 2015 06:07 AM
