Anyone sell stroker kit for my 267 shortblock?
Old Sep 19, 2000 | 01:00 PM
MILT's Avatar
I'm sorry; anyways, for you stroker guys, who makes a good 383 kit, and what are the advantages of buying a kit that is balanced?
Old Sep 19, 2000 | 01:18 PM
Tas's Avatar
Tas
Scat has some deals. interaly balanced cranks won't wobble like external ones.
Old Sep 19, 2000 | 01:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
A 3.75" crank (the stroke that turns a 350 into a 378, or a .030" over 350 into a 383) won't turn your 267 into a 383, it will turn it into a 288. HUGE maze, no cheese.
The 267, 305, and 350 all have the same 3.48" stroke, but different bores. You'd be about $1000 and 20 to 70 cubic inches ahead if you just went to the junkyard and got a 305 or a 350, which are therefore basically bored-out 267s. The 267 already has too little bore for the stroke it has. All the 305 performance problems, such as the bore being too small to accept decent-sized valves, would be amplified with a 267 block. I'm not telling you what to do, but IMHO the 267 is not a suitable choice as a platform for any kind of performance build-up.
Old Sep 19, 2000 | 01:55 PM
Tas's Avatar
Tas
I think a 327 crank in a 267/283 block was the old 307. a 350 crank might get you a 315 if I remeber, a .060 over 267/283/307 block and 350 crank was 5.2L (I wanted to find a chevy combo that would be 5.2L like mopar )
AOL IM: superGRtaz
ICQ: 82881207
Old Sep 19, 2000 | 02:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Tas:
The 267 is not the same bore as the 283 and 307. The 283 bore was 3.875", the 267 bore was about 3.50" (3.495" maybe? I'm not sure; I really don't care to be honest). The 307 was 3.25" stroke and 3.875" bore; the 327 was 3.25" stroke and 4" (same as the 350) bore.
Also, there are very few, if any, 283 blocks that have the large crank journals. AFAIK the only large-journal 3" combo ever built was the 68 & 69 302. So it is not possible to install a 3.48" stroke in a 283 block. The 307 blocks did use the large journal size, so it would be possible to put a 350 crank in one of those. That however would give you a 328 in std bore or 338 in .060" over, which would be 5.4 or 5.5 liters respectively.
Put a 350 crank in a 267 and it's still a 267, except that now it's slightly unbalanced.
Stroking a 307 was not considered by anyone as a performance option in the days when that was the raw material we had to work with, in fact no part of the 307 was considered as a performance part, period. Not the block, not the crank, not the heads. The factory thought the same thing: there was never even a 4-barrel version of it made.
Old Feb 19, 2020 | 10:36 AM
Donald short's Avatar
Re: Anyone sell stroker kit for my 267 shortblock?
Hello I have a 283 stock bore Stroker Eagle crank Pistons and rods I would like to trade or sell excellent condition
Old Feb 19, 2020 | 11:58 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Try the classifiied section youll have better luck there. Besides this topic is 20 years old!
Old Feb 19, 2020 | 01:37 PM
Drew's Avatar
10secondhopeful
Oct 30, 2008 09:21 PM
87'TA
Jun 23, 2006 06:31 PM
trueburton
May 20, 2004 04:58 PM
therckid
Jan 11, 2004 07:19 PM
91camaroRS
Apr 15, 2001 10:15 PM
