Is This Normal Heat Soak?
Old Jun 7, 2003 | 03:34 PM
DamageInc84's Avatar
I had a heat soak poblem, after i driev the car wont start, if i jump it or beat the starter it'll crank...so i went out put a new starter in it seemed to be working just fine. until the dreaded heat soak got it again... same fixes to crank it...when i turn the key no clicking nothing. Will the remote solonoid kit from summit fix this problem????some one help me plz i just moved and i cant have the car doing this to me.:hail: :hail: :hail: :hail: :hail:
Old Jun 7, 2003 | 04:50 PM
ede's Avatar
ede
heat soak is another name for having a starter without enough *** to get the job done.
Old Jun 7, 2003 | 04:57 PM
so is it the solonoid heating up?? and will the summit kit fix that problem..i went out to start it and it cranked and i beat on the car for a bit and it cranked back up after that too...so the new starter is heating up but not as bad as the other one...anyone one have anyother ideas of why its doing this and any tips you guys have would be cool
Old Jun 7, 2003 | 05:03 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
It sounds like you have already isolated the problem buddy. Get a heat shield from jegs/summit and you're golden me thinks.
The only other problem that mimics heat soak is the infamous VATS failure... and this is not your problem.
Old Jun 7, 2003 | 06:24 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
The heat shield will not fit on the SBC if you have Headers. Just buy a Mini-Starter and that will cure your Heat Soak problems.
Old Jun 7, 2003 | 10:31 PM
I def dont have a vats, i have an 87 GTA so i dont have that one, i know that a heat sheild will not fit so im gonna go ahead with the remote solonoid kit from summit and if need be a mini starter..but another question should i wrap the exhaust pipe with something maybe to absorb heat.
also sometimes when i get on the car it will throw a code 43..it hesitates and then kicks in with the power..now thats esc, but is that a bad knock sensor or more than likely the module? and very rarely the MAT sensor goes off. i unplugged it and replugged it and its been fine since. has anyone esle had these sensors go off? maybe someone can inform me of them
Old Jun 8, 2003 | 02:43 AM
Morley's Avatar
I beg to differ, I have the Summit stainless heat shield on my factory (full size) starter and SLP headers passing right by it.
Old Jun 8, 2003 | 06:52 AM
DJP87Z28's Avatar
Ok, So you made it fit. Its not a easy installation.
Old Jun 8, 2003 | 03:31 PM
Morley's Avatar
Not too bad, took about an hour and 2 small trims with tinsnips.
Old Jul 6, 2003 | 05:57 AM
Guest
Guest
Posts: n/a
Heat shield
Hi,
I have the same problem: if my engine is hot, I can not
start. I have found a heat shield in the JC Whitney 2002 catalog.
Page 194 somewhere in the middle. They write that it is made
of the same material as used on NASA's space-shuttle and it
deflects 65% of the heat.
What do you think? Has anybody this shield in his/her car?
Does it work really well?
Few days ago I created my own heat shield. It is made of 5
layers wavy aluminium but on a hot day I had the problem again.
OK, it was only once, but I had it. Is it my fault? I mean that the
aluminium shield is not good?
Thank you,
Laszlo
1984 Trans Am
http://www.agostonl.com
Old Jul 7, 2003 | 09:47 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
Id recommend going with the CSI ultralight starter. It weighs like 6 pounds so your taking a lot of weight off the car and its much smaller which puts it farther away from the headers. You can then get the DEI flexable heat wrap and put that on there and you should never have another heat soak problem.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
