help me get 400rwhp
Old Jun 12, 2003 | 02:31 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
help me get 400rwhp
So...let's try this.
intake will either be lt1 or hsr
assuming L98 block
weekend toy
no worries about emissions
anyone that has 400+, chime in. let me know your combo's.
danke
Old Jun 12, 2003 | 02:36 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
ive seen 400+ at the wheels with an ls1 along witha cam, home ported and polished ls1 heads, and a custom exuast. My friend knows him and pointed me to his web site. Ill see if i can post a link. It was in a monte carlo, btw.
Old Jun 12, 2003 | 02:37 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
word. i'd like to stay with the L98 or older 350 platform though. i'd rather not drop $5k on just the ls1 itself.
i'd also like to do this N/A
the procharger will come later.
Old Jun 12, 2003 | 07:45 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ditch the TPI. You'd be damn lucky to get within 100 HP of that, with that on it.
The more inches the better.
MiniRam or carb are the only ways you're even going to get close N/A. Neither is an option if you have a visual emissions inspection.
Old Jun 12, 2003 | 08:15 PM
Car: 88 Camaro SC
Engine: SFI'd 350
not really, i saw one for $3500 with computer and T56 trans. I really wish i went that rout rather then bought a 350. In the long run, i probably would have saved money. Now, in addition to needing a carb + dist. to replace my restrictive efi, along with heads, cam kit, and intake, i also need to look into getting another trans to replace my ailing junkyard 700-R4. All those little things (and big things) add up fast. Youll also need to make sure the rest of your car can adiquatly handle the power, that means things like SFC's, suspention mods, upgraded rear end, improved brakes and tires, and a good trans to take the power. Be prepaired to spend some money if you want to make it all work well together.
Old Jun 13, 2003 | 02:21 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
it may be cheap to get the ls1, but parts and mods sure as hell aren't. $400 for a cam?
suspension is taken care of. tranny is taken care of. tires...check. brakes...uhm...stand and pray.
Old Jun 13, 2003 | 02:41 PM
AbsoluteZero's Avatar
Get a Holley Systemax-II kit, ditch the manifold and go with the stealth ram, and there is your 400+ oh and don't forget a good set of headers and ignition system.
Old Jun 13, 2003 | 03:11 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
word...i've thought about that. i wonder how that would like a 400block instead of clean 350?
Old Jun 13, 2003 | 06:08 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
I've seen LS1's going for $3,500.00 or less SHIPPED on ebay. That is complete engine wiring, harness, ecm, tranny, you name it.
LS6 heads go on there all the time for $800.00+, get yourself a 2000 plus ls1 (comes with the ls6 manifold) and some ls6 heads, maybe a cam and you have 400+ at the rear wheels for the price of a halfway decent crate engine. Plus if you really wanted you could sell the tranny for 1000+ and make some of your money back. $5,000 and a lot of your own hard work would put an awesome engine in your car, tons of power, and the fuel economy of a modern ignition and fuel processing system.
Doesn't the z06 get like 22mpg highay and 450hp?
My opinion best way to go.
James
Old Jun 13, 2003 | 07:04 PM
James
If you want to spend $5k than go for a 6-71 blower, and strengthen up your engine and tranny a bit. It will give off a lot more power than a LS6, and look a lot cooler too
Old Jun 13, 2003 | 08:59 PM
Engine: 355
A blower make more power than an LS6? And still get gas mileage? On a stock 350, first off you would blow it up, secondly you might make just over the horsepower an LS6 would, but your engine would not be very reliable at all
Old Jun 13, 2003 | 09:36 PM
Must I quote myself??
Try reading that again. I'm 16 but I'm not an idiot. A well planned blower installation can easily produce beyond 450 hp, and it is possible for $5k. I didn't say anything about gas, and I don't believe he said he wanted 22mpg either so a blower system would work.
Old Jun 13, 2003 | 09:42 PM
Engine: 355
lol ok
If a blower is the answer to everything why isnt everyone on the boards running one?
Strengthen your engine and tranny a bit??? lmao man is that the understatement of the world. To do that, you will need a lot more than $5k. Did you happen to think of the rear end in your equation? or driveshaft? Apparently not.
Old Jun 13, 2003 | 09:55 PM
I didn't say it was the answer to everything, I was just simply saying in my own way if he wanted to go through all that stuff to just get 400 rwhp he might as well spend the time to do something cool. I'd say the reason that most people don't switch to a blower setup is the work they'd have to put into it, same reason why most people wouldn't want to buy an engine just to rip it apart and buy more parts for it. What good is two and a half engines going to do him? But I still say just go with something easy like the systemax and hsr.
Old Jun 13, 2003 | 09:57 PM
Engine: 355
Something cool?
You don't think a Ls1/Ls6 in a thirdgen is cool?
Old Jun 13, 2003 | 10:27 PM
I'm not saying the LS6s aren't cool, I'm just saying that a blower is way cooler And its really all his opinion and not mine so its whatever he wants.
Old Jun 14, 2003 | 05:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
350ci SBC, blower, headers (1.75" minimum), exhaust, 2x4 carbs, big cam.
Thats basically the best way to get 400rwhp (about 500 crank hp) IMO... most streetable anyway.
Old Jun 14, 2003 | 05:15 PM
Engine: 355
that is still more streetable to you than a worked over ls6?
Now if your talking the best way to do an easy install, than your right a normal 350 slides right in. Where's the fun in that?
Old Jun 14, 2003 | 09:26 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd go with a 400 small block.
Get a very nice set of heads , either AFR or Pro Lightning maybe 220 cc versions, port em.
Roller cam- your choice,
Holley 750 DP
Performer RPM Air Gap, Weiand Stealth or similar intake.
Run some high compression along with it.
Old Jun 15, 2003 | 03:02 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
All of you have overlooked the absolute EASIEST way to get 400 HP. BIG BLOCK!!!!!! hell you could build a 500 HP big block for under $5000 if you shop around. That is the easiest AND most reliable way to get that kind of power. Plus it will be more streetable than a small block with the same power.
Old Jun 15, 2003 | 08:16 PM
mastrdrver's Avatar
Auto or manual?
A manual will be easier then an auto, but can be done. If you have a manual heres what I say
HSR
195 AFRs/TFS
XE276/282 112LSA and accompaning valvetrain
long tubes and full exhaust
Matlock88 almost did it with a similar setup as above with an auto. He used the HSR, 195 AFRs, and XE276 with a tune he got to 380rwhp with some more still there on a SD car. You could also use Topline, but they have controversal flow #s right now and that is why I didnt list them.
Old Jun 16, 2003 | 06:18 AM
I'm not sure but if I read right he said he was using his L98 block, so most of the things posted here are void.
Old Jun 16, 2003 | 09:23 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
doesn't really matter which block. preferably something i can find in a junk yard. trying to do the real budget build here.
i can always just freshen up the 305 and throw on a procharger.
tranny is th350
Old Jun 16, 2003 | 09:24 AM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
about the ls1/6 swaps...anyone got pics?
how is clearance? changing plugs?
Old Jun 16, 2003 | 11:39 AM
Engine: 355
ls1/ls6
https://www.thirdgen.org/techbb2/sho...hreadid=157243
https://www.thirdgen.org/techbb2/sho...threadid=84423
robertfrank
Nov 24, 2009 06:11 AM
LMSkyliner
Alternative Port EFI Intakes
Jan 3, 2008 05:50 PM
89IROCZZ4
Jul 21, 2007 11:30 AM
TheViper
Jan 26, 2004 07:47 PM
Gta-Paladin
Jan 27, 2001 08:07 AM
