Smoke from the vents? WTF???
Old Sep 22, 2000 | 12:10 PM
Humvee's Avatar
While driving home from work with everything on: lights, wipers, fogs, and radio, Some smoke came out from the A/C vents. It had no odor and was white/grey color. It occured when I stepped on the gas from standing still. It freaked the heck out of me. What does this smoke mean? Could it be simply water vapors from all the rain? Or it's something more serious. Help me please!!!
1989 IROC-Z Convertible
305 TPI automatic
White with black top
Mods:
None to date... Working on it!!!
My webpage: http://mindspring.com/~humvee
Old Sep 22, 2000 | 01:01 PM
Vader's Avatar
Hummer,
I think I know where you're going with this one. If it were smoke from overheated insulation on electrical wiring, it would have been accompanied by a distinct, pungent odor. If it were steam from a leaky heater core, you should have detected a sweet odor of anti-freeze. If it was water vapor steaming off the heater core, it would have no odor and should eventually stop. Accellerating from a stop may have sloshed water standing in the plenum onto the warm heater core, causing steam.
Run the heater/vent on maximum heat with a medium fan for a few minutes to see if you can dry up the potential water.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Sep 22, 2000 | 06:46 PM
Humvee's Avatar
Whew... I drove it a little more today and it doesn't smoke at all. I'm relieved! Thanks Vader!
305 TPI automatic
Mods:
Old Sep 23, 2000 | 12:10 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
That happened to me once. Cruisin down the highway, sunny afternoon, vent on, and all of a sudden white smoke comes out of the vents. No odor, and it lasted only a second or two. It freaked me out pretty bad, though. That was three years ago and it hasn't happened since, but to this day I wonder what it was.
Old Sep 23, 2000 | 09:43 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Mine does it all the time. Is it a major problem? Will it mess anytihing up?
Old Sep 23, 2000 | 10:32 AM
Vader's Avatar
For those of you who experience this, you might want to check the drain holes at the bottom of the evaporator enclosure. Normal condensation and rainfall/snowmelt that enters the cowl intake is supposed to drain from the cowl vent and evaporator case. If the drains are plugged with debris, you may be getting enough accumulation to slpash the heater core on occassion, creating the steam. This is especially true on '87 and earlier cars without the hot water valve for the heater.
Later,
Vader
"Make Me Bad"
[This message has been edited by Vader (edited September 23, 2000).]
Old Sep 23, 2000 | 01:27 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i dunno what it is, never happened on my camaro, but it did happen when i was driving my dads 94 jeep grand cherokee, and my 95 beretta, i had the a/c on in both of them when it happened
86 Camaro with 88 305 LB9 converted to carb, edelbrock performer manifold, S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermo, and fan switch, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Aug 6, 2003 | 10:45 PM
Wilburwm's Avatar
Car: 89 T/A
Engine: 305 TBI (Hopefully LS1 someday)
Transmission: 700 R4 (T-56 is planned too)
happens to mine also, swapping the heatercore this weekend.
Old Aug 6, 2003 | 11:00 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Last time I was in a car and that happened it caught fire LOL. Poor old 1995 lumina went up in a huge fire. It was crazy. They said it started in the dash because it was melted from the inside out
Old Aug 7, 2003 | 09:33 AM
trace's Avatar
i always thought that was condensation in the chilled air coming off the evaporator? it happens to every car i've had once in a while, only with the a/c on.
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Fanatic1074
Oct 2, 2015 03:47 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
