Siphoning Gas? Old skool Q....
Old Jun 20, 2003 | 12:40 PM
89RSOwner's Avatar
Need to remove my tank, whats the best/cheapest way to siphon the fuel out? I have lung problems so I cant do the hose/spit thing, lol.
Thanks guys.
David
Old Jun 20, 2003 | 01:01 PM
ede's Avatar
ede
i use a 12v external fuel pump from NAPA and connect it to a battery. just slide a hose into the tank and the outlet into a fuel jug.
Old Jun 20, 2003 | 02:29 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hmm depending on where you live you might be able to find a crackhead and toss em a buck to start the siphon for ya... lol um does the fuel pump work or is that why your droppin the tank?
Old Jun 20, 2003 | 02:32 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Siphoning Gas? Old skool Q....
Sure you can, you don't use your lungs to suck.
Old Jun 20, 2003 | 04:56 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
The auto parts stores carry a cheap siphoning pump, it's a tube with a squeeze bulb on it, I think it's a couple of bucks.
Old Jun 20, 2003 | 10:52 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Any chance you could disconnect the fuel line at the filter and power the pump up?
Old Jun 22, 2003 | 01:45 AM
89RSOwner's Avatar
Hmmm good idea. (using the pump to drain the tank)
Im pulling it because Im stripping the fuel system for a moter swap Im doing, plus im having the 1/4 section replaced. Sparks+Vapor=bad mojo.
Now its a 95 so I will need to know what wires start the pump so I can run 12V to them. Most of the wires are gone, and the car is mostly stripped (like I said MAJOR MOTOR SWAP )
And how do I suck without my lungs, lmao!
Old Jun 22, 2003 | 02:10 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Those spihon pump things take forever to drain gas. An old garden hose with one of the metal ends cut off works the best. (The metal end will not fit down the filler tube). I would suggest getting someone else to siphon by mouth. If you use the entire garden hose, theres pretty much no chance of getting any gas in your mouth, and hardly any fumes.
Old Jun 22, 2003 | 05:33 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
[/B]
Well if you don't have an abundance of crackheads meandering around your area lol, you can put most of the length of the hose in the tank, seal your thumb over the end of the hose, pull it out real fast and let go...
Old Jun 22, 2003 | 06:29 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
After chowing down on some texaco hi-test years ago, a friend showed me how the pros do it. Put a rhose in the tank fill, cram a rag around the hose to seal it, and BLOW, not suck. The idea is to pressurize the tank, after that lower the hose to below the tank fuel level to keep it going. I've also done this with an air compressor and blow gun instead of by mouth.
Old Jun 22, 2003 | 12:20 PM
89RSOwner's Avatar
Yeah I have a old garden hose laying around, now I just need some suction!
No crackheads here..hmm.
Need suction, Must pay, neeeed suction, mussst pay?
HOOKERS!
Well, im off to the college strip! One for me, one for my car, one for me, one for my car.........
Old Jun 22, 2003 | 12:44 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
at the tack the karts run menthol and u really shoudln't come in conec t with it but we all do but a lil in ur mouth is not fun, burns like a ****. neway we all use shop vacs to pull ist out. they can get liquids in rthem and suck more than you can ever.
Old Jun 22, 2003 | 04:46 PM
SgtSkip's Avatar
I'd just drop the tank and dump the extra fuel. You figure it weighs only about 100 lbs full it should be a piece of cake!
Old Jun 22, 2003 | 05:19 PM
89RsPower!'s Avatar
actually if you fill the hose with gasoline first while keeping your finger in one end then sticking the other in the tank and drop the other in a jug real quick it will start its own siphon
Old Jun 22, 2003 | 07:51 PM
Car: 83 Z28
89rs is correct, I've done that before as well.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
