why 1.6 rockers on stock engine seem to make a slight lope?
Old Jun 19, 2003 | 07:08 PM
25thanniversZ's Avatar
just installed 1.6 rockers on stock tbi 350 and it seem to have a slight lope and a little more goose to it... wondering why this is,, as in how going from 1.5 to 1.6 made any differance??put the 1.6's in because im gonna do cam, just curious though
Old Jun 19, 2003 | 07:25 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
interesting.....
i plan on puttin some 1.6 rollers on mine if i ever get my car drivable again.
so the car feels stronger?
Old Jun 19, 2003 | 07:30 PM
yes, not like a cam or heads, but more than a good ignition and tuneup. Definately freed somthing up
Old Jun 19, 2003 | 07:33 PM
Car: 1990 Iroc-Z
that kinda excites me....
lol
Old Jun 19, 2003 | 07:42 PM
nothin special, just got the basic comp 3/8th 1.6 rockers...CCA-1318-16....got them through comercial account for $10 a piece
Old Jun 19, 2003 | 07:51 PM
OMINOUS_87's Avatar
I just put em on a stock L98 last weekend. It has an SLP catback and no cats with stock manifolds. It made no additional lope.
Old Jun 19, 2003 | 07:57 PM
Ive got full dual open exhaust headers ect........and like I said it made an ever so slight slight slight lope. I know stock stang 302's have 1.6 rockers in them and if you put 1.7 in them its sounds like ya threw a cam in them,the principle of why changing rockers is what I want to know, why do they do that
Old Jun 19, 2003 | 09:33 PM
OMINOUS_87's Avatar
What are you asking? Why do what, change rockers? Clarify
Old Jun 20, 2003 | 12:02 AM
I mean like going from stock 1.6 to 1.7 in a stang.....almost seems like it changes the cams profile.. feels like it did in my 350, I went from the stock 1.5 to 1.6 and it seemed to make some kind of a differance.....wondering why changing the rockers lift feels like ya put a mediokercam in
Old Jun 20, 2003 | 01:00 AM
rezinn's Avatar
It does have a very tiny effect on the effective duration of the cam. But not enough to make it lope when it wasn't before, I'd look to see if you set something wrong.
Old Jun 20, 2003 | 11:43 AM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
the 1.6 rockers open the valves a little faster and farther. instead of multiplying your lobe lift by 1.5 to get valve lift multiply it by 1.6.
Old Jun 20, 2003 | 11:51 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it basicly makes it act like a larger cam too
the duration at .050 changes with 1.6 rockers, because it get to .050 faster and seeming adds duration.
Old Jun 20, 2003 | 12:51 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
But none of the stock cams should lope w/ 1.6. Is it a lope or a slight miss?
Old Jun 20, 2003 | 11:53 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
maybe ya got the valves too tight.
Old Jun 21, 2003 | 12:29 AM
ronterry's Avatar
Car: '94 Corvette
Maybe the valves are hitting the pistons just kiddin...yea your not going to get a hole lot of additional duration from the change, but the higher ratios rockers well cause increase valve acceleration, among other things. These things can be a little tough on a stock valve train. Then you have to consider if the stock heads can benefit from the increased lift.
I agree that you should double check your adjustments, and maybe your timing also...
Ron
Old Jun 22, 2003 | 08:44 PM
ok...got the cam installed....now it has a noticable lope...got the dubble humps on to...chip burned...ect getting somewhere now
midge54
Dec 27, 2019 04:14 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
