too much octane possible
Old Jul 1, 2003 | 02:47 AM
1986redbird's Avatar
just that, is it possible to run too much octane in a factory motor. aside from being expensive what are the negative affects of running 110 octane on a factory motor???
Old Jul 1, 2003 | 02:50 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
loss of power.
Old Jul 1, 2003 | 02:56 AM
pat12spe's Avatar
burning a hole in your pocket
Old Jul 1, 2003 | 04:08 AM
"loss of power", any one care to elaborate on that. a little theory would be nice.
Old Jul 1, 2003 | 05:00 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Any octane level above what your engine needs is a waste of money. The higher the octane rating, the harder it is to spark. This is to avoid preignition or detonation on higher compression engines. If your engine is 9:1 it won't help to run anything more than 87. So if GM tells you to use 87 octane, then running 93 is throwing money away.
Old Jul 1, 2003 | 11:42 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
*Some* high octane fuels have a slower burn rate.
The fuel burns slower. thus without the high compression ratio
of a race motor, a stock motor would loose power.
It may need more ignition advance too.
*Some* high octane fuels have a fast burn rate. As fast as 87 octane and a stock motor would not see any power loss.
Depends on the actual fuel blend.
Further , Some high octane fuels have a different specific gravity. This would require a jetting adjustment to equal the air/fuel ratio of 87 octane street gas. A lower specific gravity fuel would need a larger jet.
As said above , you only need enough octane to prevent detonation, any more is a waste of money.
Old Jul 1, 2003 | 01:35 PM
OK, heres the deal. I have a '94 LT-1 motor in my race car which is basically stock with the exception of open headers, the motor has a factory C.R. of 10.5 to 1, I have been running 110 octane race gas in it since I installed and am wondering if that is too high for a stock High compression motor.
Old Jul 1, 2003 | 03:31 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
umm yeah, I wouldn't think GM would produce a vehicle that requires race gas, at least now a days anyways.
since it has aluminum heads usually you get away with running a little more compression with the same octane fuel. least that's what I thought i read on here
Old Jul 1, 2003 | 03:50 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Yes you can run safely 93 octane in an iron headed motor with ~10:1 compression, and with an aluminum headed motor you can run about a half to a full point higher on the same octane. Of course this is assuming you have good combustion chambers and a tight quench area.
1fast91
Sep 8, 2015 01:48 PM
masonta
Sep 1, 2015 06:40 PM
Justin92GTA
Aug 27, 2015 11:16 PM
355tpipickup
Aug 13, 2015 07:35 AM
