Muffler shop said my hedmans wont fit on my car, are they right?
Old Sep 19, 2000 | 09:34 PM
Brandog87GTA's Avatar
I have the regular hedmans designed for 82-92 camaros. They are not the hedman shorties, and I believe they are full length. They do not look like there is any way for them to fit. I cant send them back b/c it is after the 90 day peroid. Will they work?
Bright red 87 GTA with 350 tuneport. Basic mods such as K&N filter, Flowmasters, Wells MAF, TPIS air foil, Accel 8.8mm plug wires with Bosch platinum plugs, Accel distributor cap and rotary buttons.Gutted cat. Hope to port runners and plenum in about 2 weeks.
Old Sep 20, 2000 | 10:42 AM
kream-'s Avatar
i have a pair sitting right next to me..
i ended up getting edelbrock TES..
the longtubes WILL fit.. but you need to run some kind of a dual exhuast.. and that shop probably isn't willing to do a dual exhuast setup for your car.
oh it is POSSIBLE to get a ypipe made.. but it would probably be very expensive..
these are for certain people.. i found that out sadly after i had already bought them like you.
btw whats teh part # on your box?
Old Sep 20, 2000 | 11:47 AM
SteveSpohn's Avatar
I had the Hedman's (short) and their y-pipe on my car at one time, fit great. If you got the long tubes, then you'll have to fabricate a y-pipe.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Sep 20, 2000 | 08:31 PM
ede's Avatar
ede
at one time i had headman full length headers on third gen, but went to hooker shories.
Old Sep 20, 2000 | 08:55 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I have full length headmans, they fit my car great. You will need to have a custom y-pipe made to hook up to the rest of your exhaust. It cost me about $130 at my local shop.
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Flowmaster 3inch exhaust system, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
Old Sep 21, 2000 | 10:55 AM
Yeah but u dont have all the emission **** that I do, its a bigger cram in my engine bay. I am just gonna save up and get some shorties, its not worth the pain to go through all that and probably not gain much HP
Old Oct 6, 2000 | 06:27 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Hey to all that have(or had) the headman longtubes and are not using them, I was wondering if any of you still have them and are maybe wanting to sale them??? What size are the primaries??
~Clint Cain
clint_cain@excite.com
'86 Iroc
'93 Z28
Old Dec 4, 2003 | 08:27 PM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
The primaries for the longtubes are 1 5/8" with 3" collectors.
Brandog87GTA, your exhaust shop is right is some sense. The headers will fight your car regardless of what emmisions crap you have. However, they take some finese, you have to remove the starter, and they don't clear the floor pans. The last statement it what the exhaust shop probably went by. However, the exhaust won't clear the floor pans if run right off the headers. Jegs sells s shaped x-tensions that are only $22, reduce the exhuast to 2.5" so you can run a y-pipe, and give you all the clearance you need to run exhuast and you dont' have to do a dual setup either. Don't be discouraged about going longtube just because people say they won't fit, cuz they will. There are plenty of people that have done them with much success and they are able to produce a lot more torque than shorties. Not to mention the y-pipe for the shorties is 2 1/4" pipe, not much better than stock, so you'd have to modify that anyways. But hey, if you are looking at getting rid of the longtubes I'd be interested in getting em!!
Old Dec 4, 2003 | 08:41 PM
llvll4l2c91350's Avatar
i sure hope brandog has solved this problem by now seeing as it's been over 3 years.
Old Dec 4, 2003 | 08:42 PM
305RSlc's Avatar
BLAST!!!!! didn't even notice the date....oh well
Old Dec 4, 2003 | 09:32 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I had hedman LT and true duals before. If you love loud and hate driving the car then duals are cool...My got tore off by a manhole cover. Yeah it was low.
I like my TES, and 3'' hooker catback. Ground clearance is nice. Even with my new ground clearance I still can't get in my GF driveway....
Old Dec 4, 2003 | 11:11 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Most muffler shops don't want to get involved with any custom work that might take some thinking and planning etc. It cuts into their profit margin. They would rather just pull some piece of crap off the shelf and bolt it on.
How much power your car makes or doesn't make does not concern them.
Hedman long tubes will fit. You do not need dual exhaust. The connecting Y pipe will have to be custom made. You can run it into and nice 3" or 4" single pipe exhaust system with good results. The pipes that come off the headers will have to be fabricated from mandrel
bent pipe pieces and welded together.
The common premade "S pipes" are not tight enough
radius bends for a nice fit.
You want the pipes to sit as high as possible as they cross under the cross member. The trans crossmember flange edges can be shaved with a cutting torch to allow the pipes
to snug up tight and not hang down. the left side pipe crosses over to the right side just behind the trans.
More mandrel bends and welding. There is even enough room for twin small case shorty hi flow cats.
This will take time and $$ and quality work to do it right .
Most production muffler shops are just not geared up to this.
Find a fabrication shop. Or an exhaust speciality shop or do it your self. You can buy the parts and pieces from
Flowmaster, Dyno max, and Magnaflow.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZ1989
Jan 24, 2016 03:55 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
Exxon Limited
Aug 9, 2015 08:13 PM
