check engine light
Old Jul 7, 2003 | 09:35 PM
brandonjones's Avatar
check engine light
ok my thermostat froze shut this weekend so i replaced it and the upper radiator hose. Then i went to go check and see if it work i let it heat up about 10 mins and the check engine light came on. Does this mean i screwed somethign up bad or what. Its a v8 305 berlenetta
Old Jul 7, 2003 | 10:06 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
We'll have to know what the codes are so we can help you.
Old Jul 8, 2003 | 08:16 PM
ya but i need help in reading the codes....how do i read them?
Old Jul 8, 2003 | 10:07 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
I will save you the trouble of doing a search. Jumper pins A&B(the 2 on the top right) of the ALDL connector(under the steering wheel). Turn the ignition to "ON" but DO NOT START THE CAR. The CE light will flash once, pause, the flash 2 more times. That is a 12. It will do this 3 times. After that it will flash the code. (EXAMPLE, flash, flash, flash, flash, pause, flash, flash) That is a code 42. If you look at the FAQ section on the home page there is a list of codes near the bottom of the page or you could post it here and we could give you some ideas for fixing the problem.
Old Jul 9, 2003 | 04:01 AM
thanks ill try that on first light
Old Jul 9, 2003 | 08:00 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Most likely the coolant temp sensor, which sits right on top of the thermosta, is left disconnected.
Pop the hood, and go back and check your work.
Old Jul 9, 2003 | 05:13 PM
ok i checked the coolant sensor and it looked fine. So then i tried the codes, i wasnt to sure where to stop but this is what i got:
14,14,15,15,15,12,12,12,14,14,14,15,15,15,12,12,12. And now when i try to start the car, if i let it idle for a few minutes the rpm drops and it dies.
Old Jul 9, 2003 | 05:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml scroll all the way down to the bottom
12 is what you're supposed to see, it means the engine isn't running at the moment
14 & 15 are coolant temp sensor; 14 = shorted to ground (usually means the connector flopping around loose touching the engine), 15 = connector disconnected
Old Jul 9, 2003 | 06:46 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
RB is right. Check the cable to your coolant temp sensor.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
