blown head gasket-fixed but still smoke out the tail pipes
Guest
Posts: n/a
HELP!!
ok i put the new head gaskets on the car... let the car run for 15mins (at idle) open headers so it would be EZer to retorque the heads when it was running it was running nice and strong. put the headers back on started it up and it started smokeing like a bitch otu the tail pipes and some anti-frezze came out. let it just just a little bit more like and hour later and the anti-frezze stopped out of the pipes. what i want to know is could it still be smokeing cuz of all the anti-frezze in the cat and muffler??? will this go away? what the hell is going on... i'm sooooo confuesed and pissed...
PS i took the belt off and ran the car (so the pump wouldn't be pumpping) and it still did it. and it doesn't do it when it fist starts up like it use to...
AND the motor dies when i put it into gear!
You should see a massive white cloud of steam at first and then become less. It will take 10-15minutes at and idle. You can take it for a drive and will clear up sooner, assuming you fixed the problem
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Have you performed a leak down or compression check? That should tell you if the new gaskets have sealed properly. You shouldnt have to retorque the head bolts. Once is enough to get the head gaskets compressed and seated against the gasket surfaces.
Car: 88 Camaro SC
Engine: SFI'd 350
there is also the possibility that the intake manifold gaskets are leaking or the lash set improperly. As for the smoke. Its entirly possible for it to steam/smoke for quite some time if alot of coolant has collected in the muffler.
Guest
Posts: n/a
Originally posted by PLANT PROTECTION
You changed only one head gasket correct? If so, make sure you lash all valves equally.
and yes i ahve the valve lash to tight i was putting it into drive befor i set the vavle lash i didn't know that would do that.
Thanks everyone for the help!
ambainb
Apr 25, 2016 09:21 PM
