Lb9
Lb9
Exactly, what does an LB9 engine have that differntiates it from other 305's and my LB9 has had the TPI replaced with a 650cfm Holley 4777 car on a 14101074 manifold with a 1/2" spacer. What sort of HP would this engine be making, now? There has been much carnage to the emissions gear, BTW
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Not all LB9's had roller cams. The '85 and '86 did not. I don't think the 87 had roller cams either.
Any way the carb probably is not adding to the overall power much. If anything it may be less but probably not enough to notice. To take advantage of the carb a higher rpm band would be needed. A cam that produced power above 5000 rpm.
Originally posted by Cynsguy
Does anyone have specific specs on the LB9? Cam lift/duration, HP and Torque?
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Car: 1985 Iroc-Z
Originally posted by iroc22
87's had roller cams.
What year exactly is the LB9?
