heard of 202 vette heads?
Old Oct 16, 2000 | 11:02 PM
nelliesIroc's Avatar
a guy I work with says his brother has a set of almost new vette headsfor sale he thinks they are 202 heads? does anyone know anyhting about them are they worth 250 bucks?
Old Oct 16, 2000 | 11:34 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Ah.....the ever so popular "vette" heads...hmmm.
I've seen many engines called "vette" engines (and demanding a higher price) because they have corvette valve covers on them.....beware.
Please find out casting numbers. You can find out what they are at www.mortec.com or post the numbers here.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited October 16, 2000).]
Old Oct 16, 2000 | 11:45 PM
my friend from work helpsed him pull the heads in the first place and they were in a vette but his brother is out of town so i can't get the casting numbers but he thinks they are 202 heads if that means anything or not I just need to know if I should wait for him to get back or just use the heads I got now.
Old Oct 16, 2000 | 11:54 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Sorry if I came across as an *** ..
Been there, done that.
What year vette? Alot of the mid years are nothing but regular SBC heads. Nothing special about them.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 16, 2000 | 11:58 PM
it was from a mid 70's vette i believe
Old Oct 17, 2000 | 02:42 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
dont buy 'em. Mid 70's are sht! Go with something tried and trued. Don't get taken in by the "VETTE". These years were the slowest vette's (beside I-6's').
Vortec-$418
performer intake-165
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Oct 17, 2000 | 08:56 AM
Polecat's Avatar
The heads off the late 60's and early 70's were good. They were the doublehumps. They came with 62-64cc combustion chambers and drag racers loved them. The most sought after were like the 461X and the 186's.They had from 1.94 valves up to 2.02's.If they are doublehumps, for $250, they should at least be assembled.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Oct 17, 2000 | 09:01 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Early seventies could be a good set, depends on the casting #s.
Aftermarket heads are getting really cheap nowadays so it really depends on what power you want or will want in the future.
Head technology has come a long way since the seventies.
Can you get a casting number off one??
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Oct 17, 2000 | 12:53 PM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
What this guy meant is "They came off a 'vette ..." same as all other SBC stuff "... and have 2.02" diameter intake valves" 2.02" int/ 1.60" exh The 202 is not a casting number, he probably just uses "key phrases" to sound like he knows about cylinder heads. Get the numbers and match them to Mortec (as posted) or MadMike's page (which I prefer ). If you need to build a cheap engine quick, then go for it, but if you want a performance engine go with aftermarkets or (better yet if your thifty) Vortecs.
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
camaro71633
Sep 1, 2015 10:24 AM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
