"the" starter/block defect?
Old Jul 26, 2003 | 10:15 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
well, i just put in a 350. it used to start better, but now sometimes i hear a grinding noise when trying to start it. i ran a search and found that there was a problem with where the machines used to drill the holes for the starters. is it possible that the engine that i just got (350 H.O.) has that problem? when i installed the starter i even thought to myself that the starter gear couldnt move over enough to engage it all the way. i put one shim in the starter. also, i lost one of the starter bolts so i used a regular bolt, could that be the problem? thanks for the advice.
Old Jul 26, 2003 | 10:18 PM
25thanniversZ's Avatar
DO NOT use anything but starter bolts
Old Jul 26, 2003 | 10:26 PM
cr125r's Avatar
Car: 1988 trans am
also, one other thing i noticed is that when the car fires, it sounds like the starter sticks a little bit(split second) that should help to diagnose it. thanks
Old Jul 26, 2003 | 10:27 PM
cr125r's Avatar
Car: 1988 trans am
why though?
Old Jul 26, 2003 | 10:53 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
The factory starter bolts are slightly oversize on the shank to provide a snug fit in the hole so the starter can't shift.
Old Jul 27, 2003 | 04:18 AM
ede's Avatar
ede
bolt holes in starter= 7/16" starter bolts =3/8" that very well may be your problem and if it isn't it will be soon enough
Old Jul 27, 2003 | 04:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you can find replacement start bolts in the red "Help!" section of your local auto parts store.
Old Jul 27, 2003 | 06:56 AM
cr125r's Avatar
Car: 1988 trans am
awesome, thanks guys. ill ge sure to go pick one up today
Old Jul 27, 2003 | 09:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the block is newer than about 80 or 81, which it would obviously be if this is the GM "350 HO" repacement motor, chances are it doesn't have the problem with the bolt holes. Get the right bolts and life should be better.
Old Jul 28, 2003 | 05:42 PM
cr125r's Avatar
Car: 1988 trans am
well i got a new bolt and put in it in. however while i was under there i took a picture of the starter. if you look at the shaft that the starter gear is on, it looks like there is a washer type thing that holds the gear back from engaging completely on the flexplate. is this normal? thanks
also, are the teeth on the starter gear supposed to lean a little more in one direction, or is my starter toast?
Attached Thumbnails "the" starter/block defect?-untitled.jpg
Old Jul 29, 2003 | 01:20 PM
cr125r's Avatar
Car: 1988 trans am
anyone?
dcd2236
Exterior Parts for Sale
Aug 19, 2018 02:27 PM
IROCZDAVE (88-L98)
Sep 22, 2015 02:22 PM
zedder 1 9 9 0
Jul 1, 2002 12:08 AM
camaroguy99
Jun 30, 2002 03:06 PM
eric17422001
Mar 3, 2002 06:21 PM
