Alternator Change?
Car: 91 RS
Engine: 305 TBI
Alternator Change?
How hard is it to change an alternator on an L03? Also where should i get a new one from? Would one from a place like autozone be sufficiant? If not that hard to change, can someone write up some instructions for me? Thanks
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
Yea autozone would be fine.
Its easy to change alt.
disconnect battery.
take off wire lead.
Loose bolts on alt.
take off belt
take bolts out
remove alt
put in new alt
installation reverse of removal/
disconnect battery.
take off wire lead.
Loose bolts on alt.
take off belt
take bolts out
remove alt
put in new alt
Car: 92 Z28 Z03
Yea its really easy just look at how everything is.
If you get stuck on something you know where to come and ask...good luck
Car: 91 RS
Engine: 305 TBI
Can anyone tell me how to get the two screws on the bottom of the alternator out? I tried different sizes of alan wrenches and that is not working. I might have stripped it a little bit but not too bad. Is there a certain tool for this?
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
you just need the right size socket and a wrench, nothing special about it. dont keep using your allen wrench because you'll just finish stripping it off and then you'll have a problem. when you get these bolts out id buy new ones to replace them with instead of installing these to save headaches later on.
Car: 1986 IROC-Z
Engine: 5.0 TPI
Are you trying to take out the bolts that hold the alternator in the bracket or the small screws that hold the alternator case together?
eightsixseven
Dec 16, 2024 01:50 PM
db057
Aug 11, 2015 10:11 PM
