worth it to gasket match the intake manifold??
Old Jul 28, 2003 | 11:07 PM
SlowMaro's Avatar
ok so this sucker is aluminum, i dunno if i feel comfry griding aluminum, i think itll crack easy...i have a single cut carbid tip that might do the trick....even though i dont htink its made for aluminum. i have single double and tripple cut carbid tips... yet no aluminum ones. just wanting to know if it was worth the effort to gasket match them ..seeing how i gasket matched the heads... is it worth the 2 hours itll take to do the manifold????
Old Jul 28, 2003 | 11:14 PM
Rage13's Avatar
Car: 89 Firebird
go for it! every little bit helps
Old Jul 28, 2003 | 11:22 PM
SlowMaro's Avatar
do you need a *special* carbid tip for it or what, ...how easy is it to mess up aluminum....i.e. Crack it...
Old Jul 30, 2003 | 06:49 PM
Rage13's Avatar
Car: 89 Firebird
i don't know to much about it yet, i've just started porting my plenum and trottle body. you can find alot of info by using the search on this site or on google, i'll find way more then you would ever even consider reading.. as for grinding, i find the little brown grinding disks that came with my dremel tool almost perfect for grinding the metal. but i'd just try out a few things and see what works best for you
Old Jul 30, 2003 | 08:24 PM
SlowMaro's Avatar
eh i did it anyways, only too a couple hours
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
89-S-dime
Aug 12, 2015 11:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
