cheapest place for performance shortblock?
Old Jul 30, 2003 | 04:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
whats the cheapest place for performance shortblock?
400 prefered, but 383 will do...
this is for my brother.. he picked up some raggy 86 camaro and wants to do a engine swap..... thing is, hes never built a engine before, and he lives in SC (im in texas) so i cant show him..
im just looking for a good cheap shortblock that he can get, slap the sheetmetal and some heads on, and drive it... somthing with decient compression, but hes never going to run nitrous or make any huge power..... so a higher compression otherwise stock bottom end would work...
i dont know of any decient shops since ive always built my own...
any suggestions?
Old Jul 31, 2003 | 09:27 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
so noone can reccomend a good company for a performance shortblock?
Old Aug 1, 2003 | 12:08 AM
deadtrend1's Avatar
I saw this in a hotrodding magazine. Dunno how good, reliable or customer friendly this place is. Just click on the online catalog. I saw some of thier shortblock prices and they werent too bad.
http://www.golensengineservice.com/
Old Aug 1, 2003 | 12:36 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
im not a total newb but im 16 and just getting into cars and dont know all the lingo. Anyone care to quickly explain the difference between a short/long block?
Old Aug 1, 2003 | 04:46 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I was going to order my 383 from here http://www.wheelermotorsports.com/index.html but ended up getting it built from a local shop. Doug a long block is a complete engine and a short block is just crank,rods,pistons,rings,and bearings assembled in a block.
Old Aug 1, 2003 | 05:44 AM
gmsmallblockguy's Avatar
Paw Lists a shortblock 383 4 bolt 350 block 9:1,10:1 or 11:1
block,crank(400),rods,pistons,rings,bearings,cam,timing set, with balanced assembly for $1,395
Long block 383
All the above + Heads, Lifters, Pushrods, Oil pump, Gaskets, and Rocker arms for $1895
Or a 377 9:1 or 10:1 400 block with 3.48 stroke 2 bolt main
short block $1095, long block $1495
BTW 400 blocks are getting hard to find you might end up finding a 350 with a stroker crank is more common and less expensive these days.
Old Aug 2, 2003 | 05:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
shortblock usually refers to just the bottom end... the block, crank, rods, pistons, somtimes the cam is included, somtimes not...
its pretty much everything below the heads.... it usually doesnt have the oil pan or oil pump either....
Old Aug 2, 2003 | 09:43 PM
Jack G Jr's Avatar
Hey MrDude gm performance parts is having a garge sale until sept.30 check them out at www.goodwrench.com
Doobie52
Sep 11, 2015 06:19 PM
Nick McCardle
Sep 10, 2015 08:36 PM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
