aluminum 305 heads on ebay?
Old Jul 31, 2003 | 10:39 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
Is this guy for real or are these shaved l98 heads
http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
anyone got ideas
Old Jul 31, 2003 | 11:37 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I don't believe it. They are probably just corvette l98s. Either way those aren't bad heads for 305s.
Old Aug 1, 2003 | 12:03 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Theyre not aluminum. Theyre painted silver. Look at the guide plates, studs, and coolant ports. Guideplates and studs are NOT normally silver, and you can see some underspray in one of the coolant ports. Theyre painted iron heads.
Old Aug 1, 2003 | 02:54 AM
EvilCartman's Avatar
Car: '82 Z28
Should ask the weight of them hehe
Old Aug 1, 2003 | 08:35 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I really doubt the guy would sell the heads as Al. if they were CI...then again, buyer beware, huh?
I didn't see any overspray, but if they were painted, who says you can't paint Al. heads? They could have been sand/bead-blasted as well...that's make the studs and guide plates appear as "silver".
Another thing is they have the exhaust crossover, rules them out as replacement Vette heads. Also, they're perimeter bolt VC's.
Old Aug 1, 2003 | 09:38 AM
ede's Avatar
ede
i say iron painted silver
Old Aug 1, 2003 | 08:31 PM
rscamaro305's Avatar
Are there any aluminium aftermarket heads you guys would recomend for a 305? I would like them to be legal in CA too. Any help would greatly appreciated. Thanks.
Old Aug 2, 2003 | 01:50 PM
You could use l98 vette heads, but youll have to run the EGR externally.
Old Aug 2, 2003 | 02:35 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Make it easy on yourself...and at smog time. Find/look for a set of heads with an EGR crossover port.
My *guess* is with proper documentation you could run the Vette heads and reclassify the engine as a Vette engine and smog accordingly...but you'd better verify with a smog place (maybe start with a call to a local BAR place, I think there's one in Redwood City/San Carlos area) to see what kind of hoops you need to jump through.
Instead of Al, you might want to look into TrickFlow heads w/58cc Combustion Chambers and do some work on them, seach some posts from "57kid", he went with the TF's and did some work on them.
You could always work on your own heads as well.
There's really no reason to drop big bucks on heads unless you're going to compliment them with cam/exhaust and induction changes.
i/e bolting on a set of HP heads on a stock 305, won't get you much over a few hours with a diegrinder on your existing heads. Been awhile since I've been through Atascadero, nice litte ride though the mountain-ish area back to 280, IIRC.
Old Aug 2, 2003 | 09:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Cant tell for sure but they are painted silver. Look into the water passage you can see a dull area where it look like they are the real deal but the combustion chamber looks more like cast iron. ask the guy to scratch somthing to prove what material thier made of.
Old Aug 3, 2003 | 08:03 AM
Car: 86 Z28
Axle/Gears: TBD
well if anyone want more compression
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2425663161
Old Oct 13, 2003 | 02:12 AM
83 Crossfire TA's Avatar
heh, they look like normal iron 350 heads, 64cc or larger... that somebody spraybombed silver.
Old Oct 13, 2003 | 09:55 PM
RICHRAD's Avatar
I can't believe someone fell for that crock of ****....definately cast-irons with a paint job
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
dutch930
Sep 11, 2015 06:58 AM
