l98 heads
Old Aug 9, 2003 | 02:03 PM
Dingley's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
l98 heads
do you think it would be a good idea for me to put l98 heads on my lg4 v8? would i need to change anything indefintely? thanks.
Old Aug 10, 2003 | 07:24 AM
ede's Avatar
ede
i ithnk it'd be pretty pointless without other mods, or you can better spend your time and money on mods that would give you more results.
Old Aug 10, 2003 | 09:05 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
I think it would slow ya down with out other mods TBH.
Old Aug 10, 2003 | 09:24 AM
Dingley's Avatar
Engine: LG4 305
i have bolt-on mods... so, why would it be a bad idea?
plus, one of my header bolts broke off into the my old lg4 heads. so i can either spend $500 to get the hole retapped, or i can just buy new heads....
Old Aug 10, 2003 | 09:36 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would not recommend using the L98 heads.
Re-tapping a hole doesn't cost $500.
L98 heads have larger combustion chambers. They will lower your compression. If you use the aluminum ones, the static CR will reamin about the same, but because of aluminum's higher heat conductivity, your performance will suffer about the same amount as it would by lowering the CR with the 64cc iron version.
Get your existing heads fixed, or locate anohter set of them at the boneyard. They're 416 casting. There's millions and millions of them, on everything from these cars to Chevelles and Cutlasses to Caprice and other full-size with 305s.
Old Aug 10, 2003 | 10:50 AM
Dingley's Avatar
Engine: LG4 305
not just to retap the hole..... its $500 to get the heads off, get the hole tapped, put new gasket down, put head back on, and reattach header.
is it worth it to do that, or should i just get new heads? i have an lg4 mind you... and they are cast iron heads!
Old Aug 10, 2003 | 01:26 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If the $500 is for all the work you stated, most of the money is to remove and reinstall the heads - not the retapping.
Without seeing the head (is the broken bolt still in the head?) you may be able to get the broken bolt out without retapping or just retap with the head left on the engine. Heck of a lot cheaper than R&R'ing the head off the engine (if you are not going to do it yourself).
Old Aug 10, 2003 | 02:44 PM
Dingley's Avatar
Engine: LG4 305
how would i be able to retap it with the head still on the engine... its so friggin tight in there.
Old Aug 10, 2003 | 06:12 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Point here it seems, is if you cannot do the job yourself (R and R the heads)...since you mention money as a condition, factor in the 500 plus the cost of new heads.
Is it worth it?
lt500r55
Sep 1, 2021 01:30 PM
CRFred
Feb 7, 2016 11:39 PM
italiano67
Aug 31, 2015 06:04 PM
TheExaminer
Aug 19, 2015 10:07 PM
anesthes
Aug 8, 2015 09:37 PM
