speedo adjustment
Old Aug 11, 2003 | 12:09 PM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
speedo adjustment
not really sure where to post this, but as it is a general question...
I just brought home my new '87 Iroc yesterday, but the speedo is messed up. I was driving behind a friend, and when my speedo read 60mph, we were really going 70mph. Anybody know how to adjust it? I don't know if my year is electronic or cable-driven. I also gotta put in new gauges as the old one is in km thanks for the help
Old Aug 11, 2003 | 05:04 PM
Damon's Avatar
It's electric. There's a VSS (Vehicle SPeed Sensor) in the tailshaft of the tranny that connects to the ECM, which in turn runs the speedo/odo.
How to adjust: not sure. I believe that year had a set of gears on the VSS itself, but if they can be changed to different gears to alter the speed reading I have no idea.
Old Aug 11, 2003 | 05:07 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
What size of tires does it have on it. Do you know if the rear end is original? These are a few things that can affect speedometer readings. I have an 87 firebird and the speedo is electric. As far as adjusting, there are different sized gears for the sending unit in the tranny.
edit- drives me nuts when other people reply when you are typing your reply, makes a person look like a me too, what he said type of guy. lol
Old Aug 11, 2003 | 06:01 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have an 87 IROC and I'm sure mine is cable driven. Mine also read low (about 25%) and the cause is down to, I believe, the wrong speedo gears. Either the rear end gear has been changed or the tranny was swapped out and the person who did it didn't change the gears-that's what my situation is.
Old Aug 11, 2003 | 06:14 PM
Car: 1987 Iroc-Z28
Transmission: auto
my car still has the original tranny, and i dont know why the speedo gears would ever have been switched out. my rear end is original, and my tires are 245/50R/16 (don't know if that's stock size or not).
Old Aug 11, 2003 | 08:15 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
an 87 IROC will be cable.....I belive IROCs (all camaroos) were cable until 89/90 and firebirds were cable until 86/87(?)
sounds like you may need to change your speedo gears(in the trans), the gears or the rear end may have been replaced
Old Aug 11, 2003 | 09:02 PM
_max_'s Avatar
my 84 has all oem and it has a vss for the spedo no cable
Old Aug 11, 2003 | 09:17 PM
Car: 87 Firebird
Check your door jamb for the factory size tire and compare that diameter with the diameter of the tires you have now.
245/50R/16 is a 25.6" tire, if the factory tire was signifigantly taller or shorter that could explain it.
My factory tire was a 215/65 r15 and was a 26'' tire.
Old Aug 11, 2003 | 09:22 PM
Dave Y's Avatar
Engine: 4.3L V6
what car do you have? does it have a digital cluster?
Old Aug 12, 2003 | 07:28 PM
_max_'s Avatar
yup and it works after taking 2 to make one
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
