3rd gen gauges stink!
Old Aug 20, 2003 | 06:26 PM
84 Challenge's Avatar
Recently swapped the gauge cluster from my Z parts car over to my Iron Duke car. Since the speedo never worked in the Z, never knew it bounced pretty bad. The temp. gauge sticks, with a nice thump, it releases. And finally, today fuel gauge started to act up. It wonders from 1/3 tank to 1/2 tank with the car running but parked. I guess this is typical for 20 year old stuff. Guess I'll invest in a set of aftermarket gauges. What brand does everyone recommend?
Thank,
Brandon
Old Aug 20, 2003 | 06:36 PM
firebird frenzy's Avatar
hey i'll agree they blow big time i have a 84 TA and i hate them. the volt-meter tells me i always have about 20 volts the gas gauge lies and they speddo still jerks in increments of 10 miles an hour even after a cable lube. the oil pressure gauge is straight up and down the wrong way and has never moved. need i go on about what you already know. I would say take a look at JEGS i personally like their new autometer gauges i've never owned one but they have been around for quite awhile so i would imagine they aern;t to shappy.
Old Aug 20, 2003 | 06:58 PM
Old Aug 20, 2003 | 06:59 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
i just purchased a set of cheap mechanical gauges to get me by until i'm ready to invest in a top quality set of gauges. i'll probably go with autometer mechanical gauges.
Old Aug 20, 2003 | 07:00 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dang...twenty years later and the gauges don't work well....
Old Aug 20, 2003 | 07:21 PM
If my Camaro ever reached the age of 100....I still expect the original gauges to work!
Old Aug 20, 2003 | 07:24 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
lol...I guess I should be more critical...original gauges in my '57 and '59 still work.
Then again, they probably wern't imported at the time
Old Aug 22, 2003 | 10:41 AM
Vader's Avatar
<h1>Need a set?</h1>
Old Aug 22, 2003 | 03:59 PM
88ROC1LE's Avatar
Old Aug 22, 2003 | 05:55 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
hmmm...16 years old here and all mine work damn good, I guess Im one of the lucky ones.
Old Aug 22, 2003 | 06:01 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Im getting rid of this set
In favor of the Carbon Fiber Series.
Old Aug 23, 2003 | 12:48 PM
ShadowZ28's Avatar
Car: 91 Camaro RS
Engine: L03 for now......
Transmission: 700R4 for now.......
i love your guages. did you have to take apart the dash behind the original guages? is it really difficult. id love to do something like that to mine when im done with the motor
Old Aug 23, 2003 | 01:27 PM
EvilCartman's Avatar
Car: '82 Z28
Post in the classified section please.
j/k
Old Aug 23, 2003 | 01:54 PM
StreetRCR's Avatar
Car: 82 Pace car
Engine: Small block
Transmission: TH350
I just opened up the stock holes in my 82 and dropped in some Auto Meter Phantoms. They look and work awsome. With the way I did it they almost look factory..I also mouted 2 gauges in the center of the dash just underneath the vents..
Old Aug 24, 2003 | 06:44 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
i feel there might be a difference. i know already that ill have to make a faceplate. but im a little worried about the wiring aspect . thanks for all the help guys
Old Aug 24, 2003 | 06:45 AM
ShadowZ28's Avatar
Car: 91 Camaro RS
guess i probably should have said that i have the 91-92 cluster
Old Aug 25, 2003 | 03:17 PM
DaGoat's Avatar
Sending you a PM.
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
tricky1
Aug 23, 2015 01:17 PM
reiderz iroc
Aug 13, 2015 04:57 PM
ChevyZ71
Aug 13, 2015 07:30 AM
