Gauge Cluster Indicator Lights
Old Aug 23, 2003 | 02:54 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
In this pic and also in my gauge cluster, you see all those places for the indicators, like check engine, etc. I was wondering what does each of those indicate? There are 8 of them! I cant even think what they would warn you about!
Old Aug 23, 2003 | 04:35 PM
demonchild's Avatar
use a flashlight!!! most of them are blank. iirc there is a service engine soon, brake, seatbelt, and oil??? you dont really need the lights, that is were the gauges come in handy.
Old Aug 23, 2003 | 05:58 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
INFL REST for the airbag
Old Aug 23, 2003 | 09:50 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There is also a fuel economy shift light for the manual cars..
Old Aug 24, 2003 | 10:20 AM
Vader's Avatar
...and a space for a CHOKE lamp on carbed cars, and a VATS or SECURITY lamp on others.
Old Aug 24, 2003 | 11:18 AM
Vader's Avatar
I'm not certain what the last empty space might have been used for:
Old Aug 24, 2003 | 12:47 PM
JT's Avatar
JT
Community Administrator
My 90's cluster has a Low Oil Level warning light
Old Aug 24, 2003 | 04:27 PM
warrior_91's Avatar
Car: 86 T/A
What does INFL REST MEAN? and what does the choke and that key light mean?
Old Aug 24, 2003 | 04:44 PM
JT's Avatar
JT
The INFL REST is for the airbag (inflatable restraint) in the steering wheel, that deploys in certain accident conditions. The choke light was a dummy light for the choke circuit on a carb equipped engine, and the key is for the factory security system (part of the VATS system with the resistor on the ignition key). Though mine just says Security on both my notchbacks.
Old Aug 24, 2003 | 06:11 PM
deadtrend1's Avatar
on vaders pic, the blank light should be the "Security" lamp.
Oops, maybe not .... thats a older dash then my bird had.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
ChevyZ71
Aug 13, 2015 07:30 AM
