How to ID tuneport motor in car
Old Nov 5, 2000 | 11:37 AM
Coolcars's Avatar
I just bought an 86 IROC and the motor in it has center bolt valve covers. That should make the motor newer than 86 Doesn't it. Also is there any way to tell if its 305 or 350?
2E,87 Formula 350, 4 other Camaro's & 3 Firebirds to fix, Drive, or sell.
Old Nov 5, 2000 | 11:52 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I am almost positive that 87 was the first year of centerbolt valve covers, but I could be wrong. Since it's not the original motor probably, the stickers won't be accurate for engine size. You can try a few things. The size of the block is usually stamped on it somewhere. I think it's in the rear, but I don't know which size. The only other thing I can think of off the top of my head is if you happen to pull one of the heads off, you can measure the cylinder bore. Anyone else have any ideas?
Old Nov 5, 2000 | 12:58 PM
Vader's Avatar
Cool,
The casting number for the case is located on the rear ledge of the block just to the left of center. There should also be a four-digit date code for the casting. Remeber that the model year production typically begins in September, so a "10-86" casting would be for a 1987 Model car.
Check the casting numbers at www.mortec.com.
Incidentally, the center bolt rocker covers were introduced on the 1987 model year.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
1992rs/ss
Jan 31, 2025 05:10 PM
jhawkeye
May 25, 2022 06:33 PM
slade5612
Aug 11, 2015 07:19 PM
1nastygta
Aug 8, 2015 07:38 PM
mustangman65_79
Aug 8, 2015 01:18 AM
