quick help on TBI air cleaner
Old Nov 3, 2000 | 02:34 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
im painting my air cleaner housing. i took off the "vacuum diaphram motor. i looked inside the inlet...and i see a little flap "the damper door" it looks restrictive....is it helping or hurting me...can i take it out. thanks
Rick
90 Camaro RS 305 TBI
350 on the way!!
Old Nov 3, 2000 | 03:27 PM
Scott C's Avatar
If you want your car to act like stock, then keep the flap. The flap is there to either allow or restrict hot air to the intake. See that flexible tube attached to the bottom of the flap area and then to the exhaust manifold? That's where the hot air comes from. The flap closes upon startup to allow hot air in, and once the engine heats up, it opens to let fresh air in.
Just FYI: the entire stock air cleaner assembly is incredibly restrictive. If you want a nice power increase, get rid of it and install a open element air cleaner for about $30. It's worth at least 10hp.
Old Nov 3, 2000 | 03:56 PM
Car: 90 Camaro RS
Engine: 305 TBI
yeah i know. (about the restriction) thanks. so i can take it out?? i dont think it even works soooo i might take it out. im gonna get an open element xstream k&n. but not on this engine...the 400 thats a'comin. thanks for your help.
Rick
350 on the way!!
Old Nov 3, 2000 | 08:03 PM
Andy89RS's Avatar
You can gut it, but if you get some ****-retentive ******* when smog check time rolls around, you won't pass.
"Racing is life. Everything else is just waiting." - Steve McQueen - LeMans
305 TBI, T-5. 15.4@92 mph
Member Southern California Third Gen F-Bodies
AOL IM: Andy89RS
Old Nov 4, 2000 | 02:36 AM
Car: 90 Camaro RS
Engine: 305 TBI
if i gut it will it help or just do nothing
Rick
400 on the way!!
Old Nov 6, 2000 | 04:40 PM
Scott C's Avatar
If you're not going to go with an open element air cleaner, then just leave it alone. That way you can put it back on when it's time to sell the car or pass emissions.
Removing the flap isn't really going to improve the stock air cleaner assembly. It's only closed during startup anyway.
Old Nov 6, 2000 | 04:44 PM
Car: 90 Camaro RS
Engine: 305 TBI
i just tried it out today i started the car and that thing didnt budge. it justs stays flat...alowing cool air in. either its been broken for sometime now or i didnt put it back together right...which isnt rocket science.
Rick
400 on the way!!
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
BurlyChev
Aug 22, 2015 01:52 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
