Holley Stealth Ram Questions
Old Aug 27, 2003 | 07:40 PM
dennis6's Avatar
Car: 1991 Camaro RS
A few questions on using a steatlh ram...
Using Holley #7540 will a TPI intake fit on the stealth ram or do I have to use an LT1 intake. If I have to use the LT1 intake, is the TPI ECM and wiring harness compatible?
Also, will any GM fuel rails or/and injectors work with the stealth ram?
Old Aug 27, 2003 | 08:07 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I could be wrong, being that I'm not interested in the HSR, but I think it's a complete intake by itself...i/e you wouldn't be using the TPI's original runners, intake or plenum.
have you tried a search on it? I recall a "HSR Sticky" thread, that was posted by a moderator...should tell ya all ya need to know.
Old Aug 27, 2003 | 08:11 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I juts clicked on your link...
What you're pitcuring is what would be equivilant to lower base/runners/plenum assy on a stock TPI setup.
From there you'd need a TB, rails, injectors, etc...to make to work...do a search, all the info you seek is posted in one thread...I think with part numbers as well.
Old Aug 27, 2003 | 09:51 PM
cp87GTA's Avatar
Car: T/A / Grand Am
Engine: 383 SBC
Transmission: glide
Axle/Gears: 9" ford 5.67
Re: Holley Stealth Ram Questions
It's best to use Holleys fuel rail, made for the intake. GM injectors, & throttle body do work . Fuel line will need some modifing. I used steel line, with GM ends silver soldered to mate with my stock lines. When I sell the car the HSR will be for sell separately.
Old Aug 28, 2003 | 05:19 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
click the green banner and most answers will be revealed.
the HSR is a stand alone intake. it replaces the stock plenum, runners, and base.
you cannot use the stock fuel rails. yes you can reuse your injectors.
yes the stock ECM and harness will work.
dennis6's Avatar
Car: 1991 Camaro RS
Done multiple searches before I posted. I always do.
So there is no way I can use GM fuel rails? I don't really want to pay 200+ dollars for a fuel rail.
Old Aug 28, 2003 | 05:26 PM
mrr23's Avatar
Engine: 360 HSR
as stated in the FAQ section over at www.stealthram.com , no. will not fit. nno way, no how. regulator housing hits the runners and not wide enough. look at the cost to swap section over there also. i created www.stealthram.com to answer these types of questions.
Old Aug 28, 2003 | 05:28 PM
dennis6's Avatar
Car: 1991 Camaro RS
Not so worried about the regulator, I think I can figure something out. Will LT1 Fuel rails fit?
Old Aug 28, 2003 | 05:40 PM
mrr23's Avatar
Engine: 360 HSR
you'll have to figure a way to tie the 2 rails together to get fuel to both of them. and get them bolted down to hold the injectors into bosses. can't just let them freehang. the vibrations will pop out the injectors. you'll spend many hours trying to find something to work. plus cost of materials. now how much is your time worth to you? it's nice to be different and innovative. but time is money.
Old Aug 28, 2003 | 06:01 PM
dennis6's Avatar
Car: 1991 Camaro RS
Old Aug 28, 2003 | 06:08 PM
dennis6's Avatar
Car: 1991 Camaro RS
Guess I will be buying 200+ dollar fuel rails.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
L98GTA87
Aug 11, 2015 06:55 PM
