Too much for a 350??
Old Aug 28, 2003 | 10:29 AM
88ROC1LE's Avatar
Old Aug 28, 2003 | 10:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like the old "Stage 2" cam...
He'll hate it, and will be replacing it soon.
Old Aug 28, 2003 | 10:47 AM
ede's Avatar
ede
might be a lunati bracketmaster, i've used them in 350s before, decent cam, about the limit on stock converter
Old Aug 28, 2003 | 10:48 AM
88ROC1LE's Avatar
Old Aug 28, 2003 | 10:57 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I guess he'll find out when he puts it in. Until then, it's just that, a guess.
Old Sep 3, 2003 | 10:51 AM
88ROC1LE's Avatar
Old Sep 3, 2003 | 11:45 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
quite the mechanice huh.
Old Sep 3, 2003 | 12:55 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Everyone Ive talked to say its better to go aftermarket than double humps. They say by the time you get all the work done to make them a good head you have more in them than a decent set of aftermarket heads.
What caused all the pushrods to bend? Cam installed wrong?
Old Sep 3, 2003 | 01:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Wrong springs, wrong rockers, heads not prepped properly, other general mechanical failure (where the mechanic failed to do something right)
That's mostly true about heads. Back in the old days, before CNC casting, there was no such thing as aftermarket street performance heads; the only ones there were were race-only, and cost mega$$$$. The only real option for a street build was to work up the best stock castings available which was double-humps. Nowadays there's all these other choices available; for what it would take to buy a set of those sought-after old castings, and do all the work required to make them competetive with modern aftermarket heads, you'll have as much or more in them as you would just buying new ones over the counter. It's all about economics.
Old Sep 3, 2003 | 02:50 PM
88ROC1LE's Avatar
Old Sep 8, 2003 | 11:24 AM
88ROC1LE's Avatar
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
