110 octane
Old Aug 30, 2003 | 05:41 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
110 octane
If I ran 110 octane in my stock LG4, would it hurt anything? thanks in advance.
Old Aug 30, 2003 | 05:53 PM
darbleinad's Avatar
Car: 84 Trans Am
its entirely unneccessary. setting the timing on the vehicle so it has the most power/performance (you can determine this by altering the timing and watching the effect on ET or on a dyno) and then run the lowest octane you can without the motor detonating. this will give you the most performance. 110 octane in a motor that doesnt need it is a complete waste of money.
Old Aug 30, 2003 | 07:01 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Hes dead on right, 110 is unnessecary. 89 is probably the highest you need. I run 87, but it don't give me great gas mileage. I'm going to go to 89, if it don't help, I got a fuel pump failure.
Oh yea, edited to add, but 110 octane is leaded gas I believe. You run leaded, you will kill your emissions equipment, which isn't a bad thing if you can get by without it. Probably knock your o2 out of wack too.
Old Aug 30, 2003 | 07:36 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: 110 octane
Just your wallet
Old Aug 30, 2003 | 08:13 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
you can get it with or with out lead, high lead, low lead ect. but, as you can guess the price is very high with out lead and low lead and also very very hard to find. if you go to sights like turbo blue and other similar makers they all seem to have differant oct. for each of the lead and none lead styles. like they said above it will give you nothing just problems
Old Aug 30, 2003 | 10:09 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
at the track i go to they have, i believe, 105 and 110 which cost $4/gal and $5/gal, respectively.
Old Aug 30, 2003 | 11:55 PM
Jgolden314's Avatar
Car: 1999 Z28
Transmission: A4
thanks for the info.....you arent joking about the high price of it....i was just checking because it smells good....
so how much would it help on the quarter mile vs lets say 89?
Old Aug 31, 2003 | 12:56 AM
darbleinad's Avatar
Car: 84 Trans Am
for a stock LG4...none. might even make you slower cause it doesnt burn as complete as 87 or 89.
Old Aug 31, 2003 | 06:21 AM
ede's Avatar
ede
you'd slow down in because it's harder to light, octane has nothing to do with power produced
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
355tpipickup
Aug 13, 2015 07:35 AM
