How long can I leave antifreeze in my oil pan?
Old Nov 5, 2000 | 10:54 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I did an intake swap about a week ago and the antifreeze that went into the engine is still there. Can i leave it there till i get a chance to change the oil. or will it damage stuff. Thanks.
Old Nov 5, 2000 | 10:58 PM
JETHROIROC's Avatar
I don't see why you shouldn't change it ASAP. It only takes a small percentage of water in oil to cause significant damage. As a good rule of thumb, anytime you expose engine internals (e.g. - intake manifold swap, valve stem seals, etc.) change the oil. It probably won't hurt anything, but it's not worth the risk.
Old Nov 6, 2000 | 08:28 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I blew up a 88 mustang gt motor that way,By not changeing the oil,I though I could drive it a short distance before the cahnge boy was I wrong.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 6, 2000 | 11:15 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Remove it immediately.
Coolant is very corrosive to bearings.
I had a 2.8 that had an intake leak and the customer didn't want to fix it so he gave us the truck.....it sat for 2 weeks with coolant still in the oil.
I pulled the engine and the whole inside of the engine was rusted. Rockers,pushrods,etc.
The bearings were all wasted and had actually rotated a crank bearing in the block.
Keep in mind that the engine ran fine and didn't knock until it was run with water in the oil. It was only run until the temp started to go up. Then it was towed to my shop.
I'm not saying this will happen in all instances...its just food for thought.
I would change the oil ASAP.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 7, 2000 | 12:28 PM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
change it, don't drive anymore. It will kill your engine.
Old Nov 7, 2000 | 04:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Oh i'm not driving it its in for the winter i WILL change before i start it up. I just didnt know if it sitting at the bottom could ruin somehting thanks for the warning guys
Old Nov 7, 2000 | 10:02 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
The mixture sitting at the bottom will develop moisture and start the rust process.
I would put new oil in it, start it and let it warm up...then park it for the winter.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 7, 2000 | 11:36 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
change the oil dude!
Old Nov 8, 2000 | 06:39 AM
BLACK Z's Avatar
Car: 86 Z28
Today!
Old Nov 8, 2000 | 10:14 AM
Mark W. Winning's Avatar
Even if you do not run the car, the water will settle on top of the oil. Maybe just enough to hit the crank. Can you say rust ball!
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Nov 8, 2000 | 11:15 AM
rondubbs's Avatar
i heard that mixing half oil and half anifreeze maeks the engine run cooler.
Old Nov 8, 2000 | 12:53 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
The GM Tech down the street said let it sit a littel cause teh antifreeze is heavier then the water and when i pull the plug the water will come out first.
Old Nov 8, 2000 | 03:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Still, either way, when that plug is pulled, the oil and antifreeze are going to come out. C'mon man, do the oil change!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 8, 2000 | 03:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I WILL do the oil change when i ahve TIME I go to school get home at 3 start work at 3 get home at 9 and the car isnt even here its put away 10 miles away. I'm not it he mood to go over there at 9 at night in the middle of the dark and try to change oil
Old Nov 8, 2000 | 05:04 PM
Blade's Avatar
HEy dude it's YOUR car and u do what you want. Don't come back here whining that your engine will need to be rebuilt though. LOL
Old Nov 8, 2000 | 05:06 PM
BLACK Z's Avatar
Car: 86 Z28
Well hey do use a favor and let leave it n there and time how long it takes for your motor to go to hell.
Old Nov 8, 2000 | 08:04 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
It doesn't matter to "let it sit for a little" the water will seperate overnight.
All we are trying to say is that letting the water stay in there any amount of time is too long, period.
You are increasing the chances of rust and bearing failure every day you leave it in there.
You asked for our advice, you got it.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
[This message has been edited by Engineboy (edited November 08, 2000).]
Old Nov 8, 2000 | 08:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I know I know If somebody was asking this question I'd be yelling too. I am cutting class tomorrow to change it ,but i wont be able to start the car cause it still in apart. Does that matter?
Old Nov 8, 2000 | 10:26 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
The important thing is to get the water out of the crankcase.
I would start it and circulate the good oil as soon as I could.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 9, 2000 | 10:15 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
$5 in oil, $1500 in rebuild... doesnt seem worth it to me.
Mark Lock
- 86 IROC-Z - Torn down for 383/SuperRam T56 setup
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Nov 9, 2000 | 01:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
It wasnt that money was the problem. I didnt have any time. But today it is now changed and the old oil looked good. Just a little discoloration.
MoJoe
Sep 24, 2015 09:12 PM
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
