How to break in a new hydraulic roller cam?
Old Sep 5, 2003 | 10:18 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Well I should be getting my car running again this weekend with the new cam and ported intake. It's the LPE 219 cam and I just wanted to know the proper break in procedure. The engine isn't new, only the cam.
Old Sep 5, 2003 | 10:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No break-in required; change the oil after a few hundred miles.
Old Sep 5, 2003 | 02:26 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I agree, just change the oil after a few hundred miles. As long as everything was prelubed properly you should be fine.
Old Sep 5, 2003 | 04:59 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
they "say" to run the engine at around 2 rpm for 20 mins to break in a cam, i say they are silly =]
Just lube the lobes of the cam and don't forget to shoak your lifters in oil to charge them before you install them
Old Sep 5, 2003 | 07:46 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
2 rpms? hum? I guess thats by hand right just kidding
Old Sep 5, 2003 | 07:50 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
lol oops, I meant 2k.
thats 2000 rpms for the mentals like me.
Old Sep 5, 2003 | 09:38 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
that's for a flat tappet, not a roller
Old Sep 6, 2003 | 01:08 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yup, 2-2.5 grand for 1/2 hour is for a regular cam, not a roller.
A roller is basically Plug and Play for a fdew hundred miles if you prelube it right.
Old Sep 7, 2003 | 07:18 PM
Car: 89 IROC-Z
Engine: 383
Thanks. Unfortunately I didn't get everything back together yet. Damned Super Ram is still a PITA to install even on the 4th time! I also had a hell of a time getting my plugs back in....I still can't get 2 of them tight. Tomorrow maybe I'll get everything all buttoned up after work. All I have left is the two plugs that aren't tight, cap and wires, fans, coolant, coil, and a header bolt that broke in the collector that I have to drill out. Oh yeah and then the great fun of setting the valves after!
Old Sep 8, 2003 | 02:50 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
20 minutes at 2000rpm
junkcltr
Aug 2, 2019 11:12 PM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
bdads
Aug 24, 2015 06:01 PM
