How many ft. lbs on the damper bolt?
Old Sep 6, 2003 | 10:54 AM
RICHRAD's Avatar
that's about it . Will the motor turn before I reach correct lbs?
Old Sep 6, 2003 | 11:31 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
65 ft.lb. with oil on the trreads, check this chart out
Torque chart
Old Sep 7, 2003 | 09:29 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Sometimes it'll turn. On the fresh rebuild it didn't but after a few thousand miles it would turn at 60lbs.
Old Sep 7, 2003 | 10:44 AM
RICHRAD's Avatar
OIL !! I found the info in my Haynes finally, but I put locktite blue on the threads. Should I redo, before it sets up...and thanks for posting the info guys
Old Sep 7, 2003 | 12:25 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I wouldn't worry about it, as long as the damper was a good snug fit and you have the screw tight it's not going to come loose, and loctite usually sets up in a matter of minutes, so it's too late for that.
Old Sep 7, 2003 | 11:09 PM
RICHRAD's Avatar
Yeah I went with the locktite because I was unable to use the lock washer that came with the Summit harmonic bolt kit. With that washer there just wasn't enough threads to feel safe about it.
Old Sep 9, 2003 | 07:04 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Some people scoff at me for this but I have done this too many times to mention. It works perfect. Listen CAREFULLY before commenting. I use an impact drive and give it 2 VERY VERY SHORT pops. BAP-BAP-BAP. Stop. BAP-BAP-BAP. Done. This gets it tighter than if you would do it by hand but not so tight as to exceed factory torque or strip anything. I would never trust doing it by hand unless you have somebody to stop the engine from turning. The key here is that you don't want the bolt coming out on the road .... but you DO want it to come out when you need to remove it. Trust me - you do NOT want that bolt coming out on the road. If it does then you will have serious problems on your hands. I always use anti-sieze on the threads because the last thing you EVER want is for a damper bolt to crack off in the crank. Always use a high quality damper bolt. I'm using a ARP one. It's worth the $20.
Tim
Old Sep 9, 2003 | 08:39 AM
Steve89GTA's Avatar
I'm using a Moroso after I stripped my stock one. It's much stronger
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
Strick1
Sep 4, 2015 07:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
