Same exact engine, what makes more power: TBI or TPI?
Old Nov 12, 2000 | 10:16 PM
Scott C's Avatar
My engine is in my sig. What setup will give more power and at what rpm range? Consider a Modified TPI setup against a Holley 670TBI and TBI intake.
I was reading TPIS inside hints and they have many comparison charts which show stock and modified TPI making lots more low end power than carb. TBI would act similar to carb.
'92 RS, ZZ4 10:1 350, Edelbrock 6085 heads, Crane 208/214 467/482 cam, GM/LT4 1.6 true roller rockers, Holley Projection TBI intake, Holley 670 TBI, SLP/Jet-Hot 1-5/8" headers, Catco 3" cat, Flowmaster 3" catback, Hughes 2500 stall converter, stock 700R4, Auburn Pro posi w/3.42, 17x9" SS rims w/BFG tires, Medium Quasar Blue w/white SS stripes, 48,000 miles....
Old Nov 13, 2000 | 12:35 AM
Vader's Avatar
Scott,
Just my 2¢, but I'd guess you'll be better off with the TBI and shorter intake runners. Your stall speed and cam grind are going to want to run at higher RPMs, right where a TPI starts to get inefficient. TPI engines make more power at low RPMs, but your torque converter and 3.42 gearing have just taken that out of the equation.
The little bit you'll lose at the line (maybe) will more than be made up when your tach hits the 6's. With your gearing and converter, that won't take long. I just hope the transmission will handle the higher RPM shifts with the extra power. I'd be a bit surprised if you don't make 13's at 650' ASL.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited November 12, 2000).]
Old Nov 13, 2000 | 02:08 PM
Scott C's Avatar
Thanks Vader! I was hoping for an intelligent opinion and I got it. And you're right, I'm very concerned about the stock trans. A few 6000rpm shifts and it's rebuild time!
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Fronzizzle
Aug 9, 2015 01:15 PM
