Loose Rocker Arm Valve Nuts
Old Sep 9, 2003 | 03:43 PM
Layne's Avatar
Hi,
Does anyone have any ideas why all the nuts on my rocker arms would be loose under the valve cover? 89 camaro Iroc, 305 Auto TPI.
Is this something I should have adjusted with a pro valve adjustment or is this a symptom for another problem?
Thanks,
Layne
Old Sep 10, 2003 | 05:34 AM
ede's Avatar
ede
factory nuts? if so replace them, poly locks? if so after your run the valve and tighten the set screw turn the nut a bit more.
Old Sep 10, 2003 | 07:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Or, simply get 16 regular nuts at the parts store, and use them as jam nuts over the stock ones. 3/8"-24 (SAE fine thread)
db057
Sep 4, 2015 07:57 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
