Mmmm... I think I made a mistake... (wrong heads?)
Old Sep 13, 2003 | 04:51 PM
Drowned's Avatar
I just ordered some new heads... this ones to be exact:
http://www.procylinderheads.com/223260020a.asp
Anyways, I'm pretty sure they are too big for my setup... It's a 350 with a 216/228 cam... 10:1 compression...
I already have the heads... I just don't know how the engine is going to respond with them Any ideas?
Will a better cam fix the problem? or are they just too damn big that I should start looking for a 400?
Old Sep 13, 2003 | 04:59 PM
Drowned's Avatar
Also, would changing the cam to a roller setup help me out?
Old Sep 13, 2003 | 05:51 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Did you get the 64cc or the 72cc chamber?
Notice under Application: "Max Street performance, oval track & drag bracket, 383 - 400cu" up to 7500rpm."
Sounds like it flows pretty high...but at least a 64cc chamber wouldnt be very radical for your engine size. 72cc would definitely be too big though... Plenty of 302/305's are running 60 or 65cc chambers...
Provide more info on the cam also...I assume those durations are at .050. What's your lift rated at the cam?
Old Sep 13, 2003 | 11:26 PM
Morley's Avatar
With 220 cc intake runners your heads are going to out flow most intakes (especially if you are using TPI).
Old Sep 14, 2003 | 08:03 PM
Drowned's Avatar
This is my cam (#5):
http://www.cranecams.com/master/apps...#5.%20CompuCam
Yes, that's at 0.50, an this are the lift numbers: .454
and .480
Yeah, I noticed... my torquer II manifold is way too small for those heads... I need to get a Victor Jr. manifold That's too much IMO
Old Sep 14, 2003 | 09:36 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I think that the heads are way too big for a 350. Your bottom end will be really soggy until you reach really high RPM's. I personally wouldn't go over 190 cc's. 220's will kill your low end torque.
Old Sep 14, 2003 | 10:16 PM
Nixon1's Avatar
Huh.... It's a high performance cam, but it doesnt have much duration and it's pretty low-lift.... Havent seen that before.... Maybe it's in the lobe shape.....
Old Sep 15, 2003 | 02:49 PM
Drowned's Avatar
I guess I'll need to find a 400 sbc then
Old Sep 15, 2003 | 02:55 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You could always make a nice 383
I bought a set of AFR 210cc (really 215cc) Race Ready heads for my new 383.
Course I'm gonna use a 2 inch 4 hole spacer and a big roller solid cam.
Old Sep 15, 2003 | 09:42 PM
Nixon1's Avatar
Very true... Keep the motor and push it to the edge!!
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Jan 9, 2020 08:29 PM
Reddeath210
Oct 6, 2015 08:20 AM
bamaboy0323
Sep 3, 2015 06:07 AM
dhonda200
Aug 11, 2015 11:50 PM
