cutting intake bolts
Old Nov 17, 2000 | 11:56 PM
RacerZero's Avatar
i posted a question earlier about trouble getting my intake off. well, i've got all but two of the bolts out and they are absolutely impossible to get off. i have broken off FIVE torx bits trying to get these bolts off, and yes i am turning them the right way. i don't think the previous owner knew the difference between a torque wrench and a harmonic balance puller so i have no idea what they were torqued down to. so since now i've got the broken off torx tips stuck inside the bolt heads and i can't seem to get those out i'm left with just cutting/drilling the bolts or some other method for extraction if anybody has any ideas. so what is the best way cut these out? i'm assuming i'll need some kind of cut-off wheel but what would work best? thanks
Old Nov 18, 2000 | 07:42 AM
ede's Avatar
ede
just a WAG but i'd say the bolts have loc-tite on them. heat will melt it out, but that may not be easy or safe to do. if you can cut them off and get the intake off you may be able to use a pipe wrench on what's left of the bolt.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 18, 2000 | 09:20 AM
Jester's Avatar
for a last ditch, try cutting a groove on the outside edge of the bolt, then get a chisel in it and try to hammer it loose.
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
