Is 110 lobe seperation going to work with stock tpi motor
Old Nov 17, 2000 | 01:51 AM
robert mendoza's Avatar
I just order a camshaft for comp, but ordered and installed the camshaft.The only problem is Igot the wrong lobe seperation.It is supposed to be 112 and I ordered 110.Is this gong to be a probblem.
Old Nov 17, 2000 | 03:14 AM
Omar's Avatar
I got a lunati cam, 218/218 @.050, with a 110LSA. You shouldnt really have a problem. You will lose some idle. If you are REALLY picky about your idle, send it back and go for the 112LSA. Did you say it was already installed?
1989 IROC-Z 5.7L
Old Nov 17, 2000 | 10:11 AM
Blade's Avatar
I have a 110LSA comp cams. The idle is just fine. You will notice every once in a while that is not smooth as silk, but then you're not driving a Caddilac are you ? lol
Old Nov 18, 2000 | 05:48 PM
CamaroX84's Avatar
I have heard that 110 Lobe Sep. will not work right with the stock computer. Anybody know anything about this? Thanks.
Old Nov 19, 2000 | 12:26 PM
md's Avatar
md
Valve overlap is what messes with the computer. A large amount of valve overlap will cause erratic vacuum at idle and low vacuum through the low/mid range. A cam ground with a tight LSA will have more overlap than the same cam with a wider LSA. Now, duration also effects overlap. You could have 108 LSA, but mellow duration and not have much overlap. You could also have 112 LSA and an agressive cam with lots of duration and the overlap will be increased. It all depends on the grind.
Are you sure you’re looking at the LSA and not “installed lobe center”? These two are confused all the time.
Old Nov 19, 2000 | 01:46 PM
Vader's Avatar
MD,
You read my thoughts. The combination of duration and LSA is the key, not just a single specification.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
1992rs/ss
Jan 31, 2025 05:10 PM
st.evel07
Aug 13, 2015 06:15 PM
marcusaw
Aug 10, 2015 08:13 AM
squiggy2
Aug 9, 2015 09:30 PM
mustangman65_79
Aug 8, 2015 01:18 AM
