compression test sucked!!!!
Old Sep 27, 2003 | 06:00 PM
demonchild's Avatar
well i just finished the compression test and all of the cylidars are between 110 and 125 psi. seems to low. what do you all think, go for the 350 build?
Old Sep 27, 2003 | 08:32 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Did you do the test while holding the throttle wide open? That is the proper way.
Tom
Old Sep 27, 2003 | 10:51 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
And don't forget to remove all the spark plugs, not just the cylinder you're checking.
Old Sep 28, 2003 | 06:36 AM
ede's Avatar
ede
besides making sure you ran the test correctly the numbers don't mean that much the big thing is they all are within 10% or so. 125 isn't bad
Old Sep 28, 2003 | 07:23 PM
demonchild's Avatar
ya, we took the engine apart, and i dont think it is worth it to replace the head gaskets, and all of the other gaskets, might as well as build the 350 up. by the way, carb was off the engine and wouldnt most people think to take the plugs out?
Old Sep 29, 2003 | 01:22 AM
AJ_92RS's Avatar
As my dad always taught me......
Assume nothing, and expect the worst.
Sorry if we offended you in any way. I guess we'll be more careful how we talk to you, OK Damien?
Old Sep 29, 2003 | 03:12 PM
demonchild's Avatar
didn't offend me, just that you would think that most people would read or ask someone with experience how to do something before they try it, but after reading these boards, maybe not...
by the way, it's demonchild.
gta892000
Aug 11, 2019 11:16 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tyeo098
Nov 30, 2015 06:27 PM
355tpipickup
Sep 13, 2015 11:35 PM
luvofjah
Sep 10, 2015 10:41 AM
