Old gas, what do I do?
Old Oct 3, 2003 | 03:02 PM
wwnf's Avatar
Car: 86 IROC
Engine: SC'ed 350
Axle/Gears: 4.11 12bolt
I recently obtained an 86 IROC that sat for 2 years and the gas tank is half full. Should I drain it? If so, I'm curious why. And if/when I drain it what can I do with that much old gas? I don't want to dispose of it improperly.
Joe
Old Oct 3, 2003 | 03:23 PM
Morley's Avatar
Drain it, it has probably lost most of its potentcy, as in it has turned to a less volitle liquid. Also there is probably a good amount of water in it from condensation from sitting stagnant for so long.
Just drain it, put it in a 5 gallon metal bucket (55 gal drum would be better) and light it (don't blow yourself up).
Old Oct 3, 2003 | 03:32 PM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Drain it, if it's got a carb, you'll probably want to take the top off and take a peek as well...
Also run some fuel/carb/FI cleaner through a couple of tanks full of gas to make sure everything stays clean.
As for disposing, I'd filter it, add some octane booster and use it in my lawn mower. If that's not an option look up hazerdous waste sites in your local phone book.
Old Oct 3, 2003 | 03:45 PM
biff85ta's Avatar
Car: 04 Vette
Seafoam it.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
