Good tuning instrument?
Old Oct 6, 2003 | 09:01 PM
cr125r's Avatar
Car: 1988 trans am
Engine: 5.7 gm H.O. crate engine
Is an air fuel ratio gauge a good carb tuning nstrument? im looking into getting the dakota digital one. http://www.dakotadigital.com/Detail....er=ODYR-13-2-C
It requires a 3-wire o2 sensor. since im running true duals, could i put one in each pipe, and put in a switch to change between left and right? also, what are the 3 wires on the o2 sensor for., any help is appreciated, thanks
Old Oct 7, 2003 | 12:34 AM
Morley's Avatar
The 3 wire sensor is nothing more than a heated O2 sensor. A standard narrow band O2 sensor isn't good for tuning, only the wide band ones are good for that.
Old Oct 7, 2003 | 05:13 AM
ede's Avatar
ede
i'd say an A/F isn't the way to tune a carb, but it could be an asset in tuneing a carb
Old Oct 7, 2003 | 07:23 PM
cr125r's Avatar
Car: 1988 trans am
then what is besides looking at plugs?
cr125r's Avatar
Car: 1988 trans am
what is a wide band o2, whats the difference?
Old Oct 8, 2003 | 01:04 AM
Morley's Avatar
A wide band reads actual air/fuel raito. The stock or narrow band just switches from rich to lean (about 350mv-700mv) and the computer adds/reduces fuel to keep it swinging in that range.
Old Oct 8, 2003 | 01:43 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Eyes Ears Mouth and Nose. NO fingers though.
seriouselly black smoke out the tail pipe or crispy white plugs dont tell you somthing then theres somthing wrong.
of course what happens when you smell it running rich but the plugs are white as lean?
Do some research, and you'll find that your running so lean its causing a mis-fire which causes the rich smell. interesting eh?
the point is, there is no magical tuning device. although widebands are coming down in price and becoming more practical, the average home user still cant afford one when that money would be better spent elsewhere, in most simply carbeurated N/A cases this is.
Just use the force and you'll be fine.
Old Oct 8, 2003 | 01:32 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
A vaccum gauge does wonder whens tuning a carb. Go to advance and get a vaccum guage, plug it into a vac line on your carb and tune for highest vaccum. It does wonders. I put a vaccum gauge on mine which was pulling 15lbs after the cam swap...managed to lean it down quiet a bit and now its pulling 21lbs of vaccum.
car runs perfect. Still runs slighly rich in the secondaries but Id have to adjust the jets to fix that.
Old Oct 8, 2003 | 01:53 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
A vacuum guage is one of the best and cheapest tools you can buy. It's a good aid until you learn hear the difference an adjustment makes.
Old Oct 8, 2003 | 05:25 PM
cr125r's Avatar
Car: 1988 trans am
a vacuum gauge it is then, should i get a gauge thats mounted on the interior, or just one that gets plugged in temporarily? whats the average price? thanks everyone
Old Oct 9, 2003 | 12:20 AM
Transmission: 4l60e
Either one will work but a temporary one is easier to see underneath the hood were you need it.
Old Oct 9, 2003 | 01:27 AM
Morley's Avatar
Average price is between $10 & $20 for a vacuum guage. Get a hand held guage, they are mostly used at idle and for the times you need it for WOT or part throttle you can tape it to the windshield.
Old Oct 9, 2003 | 04:58 PM
cr125r's Avatar
Car: 1988 trans am
thanks everyone for helping me, i will be getting a vacuum gauge.
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
ezobens
Aug 19, 2015 10:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
355tpipickup
Aug 13, 2015 07:35 AM
