will ford 24lb injectors work in my car?
just as the question states will they work? i am planning on putting a sc on my car and i know i will need these. i see gm injectors are like twice as much? i also saw in a gm magazine a tpi 350 with 24 lb svo injectors. i believe that svo is special vehicle operations right and ford is the only company that uses this let me knwo thanks!!!
1988 firebird ws6 formula350tpi msd 6al box blaster 3 coil accel 8.8 race wires hooker shorty headers hooker cat back system pro shift light a pillar gauge pod and water temp and air/fuel ratio gauges autometer oil pressure gauge b&m mega console shifter, march underdrive pullies, tpis airfoil cvr high torque starter (love it)
best 1/4 mile run of 14.44@ 96.53
this run is before the new exhaust system
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
I think TPIS sells a set of eight, 24lb injectors that are match flowed for $260. I bought a set a few years back to use on my TPI when I finally install it on my car. They still sell them for the same price. Look in any magazine for their add and it should show the price.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
should i maybe consider 30lb injectors since i am going to super charge my car? what color are the svo injectors? tpis makes injectors but i think when i looked they were like 50 some bucks a piece. can anyone else tell me anything?
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
if you have a semi stock car and add 24's you will run rich esp with the SVO's Your going to have to get a Custom chip to run those with a severely lean condition. I was going to get 24's but I decided to get the 22 MSD ones cause they said a AFPR could make the 22's act like 26lbs down the line.
thanks badbird.. did u have to change your computer?? that is something i dont want to do that is for sure. trying to keep this project to a certain dollar amount.. not by my choice but my fiances!! i have recently though started sending my new items to the adress where i am sending my car so far she hasnt caught on!! thanks again
Uhm... why would you have to change the computer when you change from 22lbs injectors to another set of 22lbs injectors?
umm kevin if u read the post right no one said anything bout changing 22lb injectors to 22lb injectors it was stock injectors to 24 or 30 lb injectors.. and i think i will only need to change the computer if i switch to 30lb right?? if i stick with 24lbs injectors i will be allright..
Whoops, you are right, I apologize. I misread it and thought the TPIS injectors were 22lbs. I think you will need a custom chip with 24lbs injectors as well, but the stock chip will work. I did have 24lbs injectors in mine when I put in the 350 the first time, and it ran rich. Nothing I could do would lean it out so I swapped them for 22lbs and had no problems since. I was using the stock chip at the time.
no problem kevin.. no one has answered the question of where u can get svo injectors at.. not that i want to put a ford part in my car but like every1 has said ford and gm injectors are the same so i guess it doesnt matter but the price does.. thanks..
by the way that makes me think of something why are gm injectors so much more?
1992rs/ss
Jan 31, 2025 05:10 PM
