whats everybodies igiton consit of?
Old Oct 9, 2003 | 11:37 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
what igition does everybody use???
i went ot a local speed shop and they wanted $260 for a igition box. the MSD 6A. an di was like WTF.
so what is everybody using
so i might order a MSD 6AL from summit for like $200+ shipping.
my igiton so far is.
MSD 8.5mm superconductor wires
MSD gm blaster coil
MSD cap and rotor
MSD distburter
ac delco igiton control module
NGK idrium IX plugs
whats everybody running i'm just a little curious-
Old Oct 9, 2003 | 11:43 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
holley anninilator ignition box
hei distributor w/ external coil adapter
mallory 8mm pro wires
msd boots
plugs and coil are still up in the air
Old Oct 9, 2003 | 01:21 PM
rezinn's Avatar
Re: whats everybodies igiton consit of?
MSD gm blaster coil
MSD cap and rotor
MSD distburter
NGK idrium IX plugs
Sounds like you've got some rare parts there. I'm wondering how much that disburter cost you, and those idrium plugs.
Old Oct 9, 2003 | 04:08 PM
Engine: peanut LB9
the irdium plugs i got from summit. for christmas last year, i was supposta get regular NGK plugs but at the timewhen my father ordered them they where out of stock. so after my father called them back and talked to a manger or sombody they upgraded them to these plugs for no xtra cost-
the regular cost of these plugs where around $8 a plug i think-
the distuburter i'm gonna have to get back to you with the exact price of it. i was fed up with the stock gm one and was having someproblems with it. so i replaced everything at once. no more problems for the last 15k miles. but i'm curious on what everybody else was and is running and how did they like it. cause i really love my MDSD stuff. (i had one problem but thats my fault. a wire came out and the wire got burnt so i bought a new set of them and i have not had a problem ever snice- but my one and only problem is MY MISTAKE, not MSD's fault. so i'm completely satsified.
Old Oct 9, 2003 | 04:10 PM
jamesbob02's Avatar
Car: 92 Z28
Engine: 357 TPI (L98)
I think he was making fun of your spelling, which is not cool.
Old Oct 9, 2003 | 04:14 PM
Engine: peanut LB9
oh ok, i'm more than a little of it right now- i have gotten about 3 hours of sleep in the last 2 days, so i apologize for my horrible spelling
Old Oct 10, 2003 | 05:09 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Original 305 Distributor, computer controlled
Accel 4 wire seperate coil
splitfire plugs (until they melted)
accel wires and taylor wires (half and half)
MSD 6BTM (same as 6al but for boost timing retard)
seems to ignite my fuel mixtures perfectly fine until about 15.4:1 A/F ratio, which is when i get misfires according to the software.
Old Oct 10, 2003 | 06:52 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Wyclef I have a MSD-6A box I will sell you for $100. It's exactly the same as the 6AL, just no limiter. I even have the wiring adapter. PM me if interested.
Old Oct 10, 2003 | 09:10 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I don't have anything special, but I'll chime in as well:
Stock external coil distributor
Accel Super coil, uh, coil
Accel high coltage cap
Accel high voltage rotor
Taylor 8.8mm plug wires
Bosch Platinum 4+ plugs
Old Oct 11, 2003 | 12:40 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
As long as your present ignition system is working properly
you won't gain a lot from going to a MSD 6a box.
The CD multi fire ignition only really shows a advantage in a real radical motor that idles real rough. (it's misfireing at idle)
A MSD box reduces the misfires.
The multi-fire feature at low rpm helps keep a race motor clean while idleing and stagging at the drag strip so it will respond when launched.
Don't expect to see $200+ worth of improvement on your car.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
ZMWojnar
Interior Parts Wanted
Sep 24, 2015 08:34 PM
Stroopwafel
Sep 11, 2015 06:38 AM
masonta
Sep 1, 2015 06:40 PM
Mkos1980
Dec 16, 2000 08:03 PM
