Camaro 1988 350TPI running RICH Problem.
Old Oct 21, 2003 | 06:04 AM
dahlman's Avatar
Hi.
A friend of mine got a Camaro 1988 with 350 TPI (MAF).
The car is running way to rich, everything on the car is stock parts.
The exhausts is black and it even smells gasoline from it.
Idle is quite high.
We have checked "on fuel pressure" (41-47 psi) and replaced basic igntion parts such as the cap and rotor.
When we runned the car with a scanner, the BLM's went down to
like 107 or something. The car runs rich in both warm and cold enginge condition. We have also checked for air leaks at the
MAF and intake plenum with started gas.
Any suggestions? All tip's are welcome!
Old Oct 21, 2003 | 06:42 AM
Vader's Avatar
What does the scanner say about O² voltage? Have you tried a new O² sensor just for comparison?
Old Oct 21, 2003 | 06:47 AM
dahlman's Avatar
Nope. But we had that in mind.
When starting the engine cold, the car is in open loop and should
not care about the o2? Or am i wrong?
Could be worth a shot, but just wanna make sure before
going out fetching new parts.
Old Oct 21, 2003 | 04:14 PM
dahlman's Avatar
Commo'n please give me some more hints
I need to try out a bunch of things in the weekend.
Old Oct 21, 2003 | 04:47 PM
Vader's Avatar
Have you checked for leakage through the control diaphragm of the FPR?
Old Oct 22, 2003 | 01:52 AM
dahlman's Avatar
Hmm. Nope, i will take a extra good look at that.
Thanks!
Old Oct 22, 2003 | 02:30 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
may also be a good idea to pressure test the injectors to make sure they aren't leaking. Does the pressure gauge show pressure holding when the engine's off or does it slowly drop?
Old Oct 22, 2003 | 03:36 AM
dahlman's Avatar
It drops slowly.
We checked that when we tested the on fuel pressure.
Old Oct 22, 2003 | 10:21 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
roughly how ling does it take to " bleed" off the pressure with the car off ?
And I heard this once from a guy who had the thick black smoke comeing out the back .......... his was an ignition module inside the distributor .
Old Oct 22, 2003 | 09:03 PM
travelinman's Avatar
Car: 89 RS, 91 GTA
Engine: lo5, lb9
Transmission: t5, a4
I just went through the same problem with my 91 gta. dumping gas, black smoke, throwing codes like crazy. unfortunately mine turned out to be the ecm.
good luck.
Old Oct 23, 2003 | 02:05 AM
dahlman's Avatar
The pressure drops like within 30 minutes or so. So i belive the
injectors are fine.
The car is not throwing any codes.
MustangBeater20
Oct 29, 2022 09:20 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
