Knock
Old Oct 23, 2003 | 12:53 PM
81LT4's Avatar
Car: 1991 GTA
Transmission: AUTOMATIC
Knock
CAN SOMEONE PLEASE TELL ME IF THERE IS A WAY TO CHECK IF THE KNOCK SENSOR IS BAD. I HAVE A SLIGHT KNOCK THAT SEEMS LIKE IT COMES AND GOES. I CHECK MY TORQ CONVERTER BOLTS
AND THERE TIGHT. I ALSO HAD MY MOTOR CHECKED AND HE SAID IT WAS NOT MY MOTOR (RODS,PISTONS,VALVES). CAN MY KNOCK
SENSOR DO THIS? PLEASE HELP.
Old Oct 23, 2003 | 09:27 PM
2kickassbirds's Avatar
Car: 1991 firebird formula
Engine: 5.8
change the sensor and run it for a day and if that does'nt work take it back.
Old Oct 29, 2003 | 07:02 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Re: Knock
There's always the old "Hit the block with a hammer" trick, but you'd need a ScanTool or Diacom to see if knock retard occurs.
Jake
Old Oct 31, 2003 | 10:54 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Auto zone will test it free. U pull it but save coolant! When they test it it's either bad, or good. nothing in between! No refund on installed elec. parts!!
Old Nov 1, 2003 | 05:03 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
I installed a coil and took it back...refund, no questions asked.
Old Nov 1, 2003 | 10:01 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Big diference! coils don't get dirty like a knock sensor does! get real man!
Old Nov 1, 2003 | 11:29 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
get real? ha, listen here chief, you said electric parts..coil is an electric part, hell its almost the most important electrical item a car has.. Dirty? Oil/antifreeze wipes off and I know someone who took a knock sensor back cause he thought his was busted and it ended up being something else.. but you have a delightful day slick
Old Nov 1, 2003 | 11:36 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
we will take anything back at advance...doesn't matter if its new used or your old part...managers there don'tr care.
Old Nov 2, 2003 | 12:16 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I guess only quality parts stores have that sign over the counter!
I suggest your buy your parts at Advance Auto so you can take that part back! I know I'm not shopping there anymore, I sure don't want to buy your dirty once-installed part that is supposed to be new on my vehicle!! (I hope slick-hydric shops there too).
Old Nov 2, 2003 | 01:03 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
look sqz, theres no room for a smarta$$... I was just saying u could in fact take the part back when you said you couldn't (get real man).. and I don't buy sensors cause my cars computer is eliminated with the carb conversion..
don't be a stupida$$, and of course I shop there... But you can go ahead and buy from wherever and get a sissy-girl clean part and spend more $ for the same thing...
nothing wrong with keeping out the dirt from under your nails
Old Nov 2, 2003 | 04:47 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
U know Hydric, I suppose U could, I just didn't want him to be suprised if he couldn't get his money back! SmartA$$ (Maybe!)
StupidA$$ (not even!) I think It's called sarcastic humor! []
I only speak the truth. If you can't handle the truth, I'm truely sorry!
Old Nov 2, 2003 | 05:18 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
well if you speak the truth, the real fact of the matter is you can... Whether or not I can/can't handle the truth isn't the point cause what you said was wrong and in fact, not the truth =] ...
its as plain and simple as that but its isn't worth fighting over...
Old Nov 2, 2003 | 06:38 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Your right! I'm no good at swinging keyboards! TRUCE?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
