Installing heads.. use sealer or lube?
Old Dec 9, 2000 | 04:59 PM
MikeC.86Roc's Avatar
Ok, simple question. 350 motor with aluminum heads and I have ARP bolts. I know the bolt holes open into the water jackets. The local machine shop guru said to use anti-sieze. ARP says moly lube or 30wt. I know this is to get an accurate torque reading with oil, but how will it seal then? I am using GM gaskets also. Oh yeah, ARP says to torque to 60 ft.lbs also with their lube. Thanks for any input fellas!
Old Dec 9, 2000 | 05:11 PM
ede's Avatar
ede
for the head bolts i use teflon pipe sealer. i'd guess it would torque about the same as moly lube would.
ICON Motorsports
1st & 3rd
Old Dec 9, 2000 | 07:24 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
You're going to need a thread sealer or chances are you'll end up with coolant in your oil in time.
Guys have different preferences as to what to use and different mag articles recommend different things too. So I guess you can choose your own poison.
I've used Permatex #2 (the dark brown, really gooey stuff) for over thirty years, with the stock recommended torque settings (those recommended by the bolt manufacturer). Haven't had a problem so I feel no need to change now.
Hope this helps.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Dec 9, 2000 | 07:55 PM
Do you think that loctite 518 gasket eliminator would work? Its an anarobic sealer that I use when sealing crankcase halves on 2 stroke motors. Its also used on the threads of the crankcase screws to prevent air leaks.
Old Dec 10, 2000 | 03:56 AM
Pat Hall's Avatar
I can't really add anything more to what the other guys said. Liquid teflon pipe thread sealant is the best way to go. You can get away with using RTV on the bolt threads(I did this a couple of times), but PTS is the best way to do it. You should do the same thing to your intake manifold base bolts as well. I've seen them pump oil or coolant onto the intake manifold surface lots of times.
Old Dec 10, 2000 | 07:41 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Yes, use the pipe sealer. GM sells a liquid teflon pipe sealant, wich is what I use. Use that, and the factory torque specs, and you will be OK.
If you don't use a good sealant, you will have a coolant leak. My good friend Hank had to drop out of competition when his head bolt started spewing coolant from lack of sealer. Do it right the first time and forget about it.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 10, 2000 | 09:41 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
To throw in my penny, I'm a Permatex #2 guy myself.
"The people always have some champion whom they set over them and nurse into greatness... This and no other is the root from which a tyrant springs; when he first appears he is a protector.
-Plato
Old Dec 10, 2000 | 03:11 PM
Thanks all, I used the permatex #2 just as suggested!
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
