need help fast
Old Dec 10, 2000 | 10:53 PM
dtpmike's Avatar
need help fast
I need help and fast. I went to get gas and then I tried to start it and nothing. At first I thought the battery was dead or the alternator. Then I had a friend jump it. I had power and I tried to start it and all I heard was clicking around the distributer. I guess it is the starter, am I right? Rigth now im parked at a texaco in a bad neighborhood so I need help fast. Anything that might be wrong that I can get it fixed quickly? Help me....
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from MrMikes.com
Old Dec 10, 2000 | 11:02 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
sounds like the starter all right.
'89 Formula 383 TPI
Old Dec 10, 2000 | 11:31 PM
mtx28's Avatar
do starters die spontaneously? ive never had one go on me, but i guess they could do that. you could have very well got water in the tank, but i'd think that it run a little , or at least till it burned the gas in the lines(which isnt much, but it should start). water is, as im sure you know, heavier than gas, but it could be the starter. first thing i'd do is get that thing the hell outa dodge before someone tries to gank it
Old Dec 10, 2000 | 11:41 PM
Vader's Avatar
Starters have to die sooner or later. One time they will operate, and the next time they won't. Usually that is at the least opportune time, too.
If you have a manual trans, turn on the ignition, get it rolling a bit and put it in third gear then let out the clutch slowly. If you have an automatic, try tapping on the solenoid and starter motor with a small hammer. This can dislodge a stuck solenoid contact disk, of free up a stuck starter motor brush. Sometimes it works. Sometimes it doesn't. If it does, get it home and plan on a starter change A.S.A.P.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
